04-12-2007, 19:32 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 374225 Status: Offline Thanks Meter: 41 | 7610 network ...what u say hAAAh 1 ---i tried changing its rf ic from 6260 pcb ..the no. of these ic were diff but many of them said tht both r same i found they were same in design also so i changed them 2---i changed antinna switch from 6260 pcb only 3--- changed pfo from 6260 pcb 4--- changed white filters and two small ic above antinna switch (1 is leg ic and 1 is 4 print ic) this 6260 parts are all ok coz this 6260 pcb was damaged by me only 2 days b4 and earlier it was having full network so i guess all network parts are ok but now m totally confused what more shld i do coz their is still no network at all some1 says change ur rf ic some1 says tht change ur antinna but plz all heros tell me wht exactly shld i do ...... help me urgent |
04-15-2007, 02:23 | #4 (permalink) |
Freak Poster Join Date: May 2006
Member: 278058 Status: Offline Thanks Meter: 81 | If it takes a long time before you get the 'no operator found' message, it is in most cases the switch. If you get this message within a couple of seconds it is pm file or RF IC. So try another switch. |
04-15-2007, 05:10 | #5 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Quote:
1, re hot the hagar ic ( if not ok follow 2nd solution ) 2, change the crystal ocsillater,it is near hagar ic. ( if not ok follow 3rd solution ) 3, re boll the hagar ic ( if not ok follow 4th solution ) 4, change the hagar ic ( if not ok follow 5th solution ) 5, change the uem ic be careful if you have experience to Rebolling and changing ics then follow the solutions, if you dont have experience to Rebolling and changing ics please dont try the 3rd and 4th, 5th solutions thank you. | |
04-15-2007, 11:12 | #6 (permalink) |
Member: 374225 Status: Offline Thanks Meter: 41 | thanxs FONER and SREE KRISHNA ....thanxs 4 helping me but im getting no operator found message after 1 min and i have changed rf ic from 6260 pcb still i have not solved my prob |
04-18-2007, 04:48 | #10 (permalink) | |
this problem is Rx section,PA ic working in Tx section Last edited by sree krishna; 04-18-2007 at 09:13. | |
04-18-2007, 09:05 | #11 (permalink) |
Member: 374225 Status: Offline Thanks Meter: 41 | sir if thi is rx section prob...then i have fix pa and done antinna jumper but i dnt get the network then also....n if u r saying this is not the prob of rf ic then above y have u said tht reheat or reball ur hagar .. |
04-18-2007, 16:02 | #13 (permalink) |
Freak Poster Join Date: Apr 2007 Location: INDONESIA
Member: 486960 Status: Offline Thanks Meter: 45 | Have you checked the "RXI/Q" signal sir....? Dont waste your time just only to change one and another IC. Many people do like this, they depend on their LUCK. They hope "LUCKY ****" in repairing hanpdhone. Its time to MEASURE with your Osciloscope, Frequency counter, Spectrum Analyzer..... |
The Following User Says Thank You to vinc3ntdave For This Useful Post: |
what think about all it MR. Elco?, Every body talk about but what he says? | urecel | NSPRO | 8 | 09-27-2009 05:41 |
What to say,just BRAVO | BVC-PROJECT | MSS Box II | 1 | 07-20-2007 07:41 |
is it chinese or japenese, please tell me what it says | megrine | Nokia Base Band 5 ( BB-5 ) | 1 | 07-01-2007 13:40 |
