Old 07-23-2008, 04:40   #1 (permalink)
Member: 594402
Exclamation 7610 not charging
7610 first time show charging after 5 min wait and show not charging.....plz help anyone
Old 07-23-2008, 04:45   #2 (permalink)
Member: 810101
Thanks Meter: 39
check this:
The Following 2 Users Say Thank You to simpleboy For This Useful Post:
Old 07-27-2008, 09:16   #3 (permalink)
Member: 604971
Thanks Meter: 3
i tried in not charging but it did t work .
Old 07-27-2008, 10:53   #4 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
bra....if battery ok and trak link ok than problem is pa.....so rehot pa if not done then change that pa.......
.:sopnil:.
sopniltelecom
Old 07-27-2008, 11:04   #5 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
first clean ur pcb properly.......
if not solve then check uem its uem problem reball it and ur problem will solve .........
post result........digitized
Old 07-27-2008, 11:13   #6 (permalink)
suntysunty's Avatar
Member: 226172
Thanks Meter: 946
Old 07-27-2008, 13:38   #7 (permalink)
Member: 165294
7610 Not Charging
7610 First Time Show Charging After 5 Min Wait And Show Not Charging.....plz Help Anyone
Just Write Good Pm Problam Solve
Old 07-28-2008, 08:00   #8 (permalink)
Registered User
Member: 241655
Thanks Meter: 3
100000% working
clean uem section &change 47k RES batt temp cheak scmatics @6600 pm downlowd
Old 07-28-2008, 08:57   #9 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
check ur track if that ok you can try uem,
7610 not charge hussam qulfa WD2 & APE (Symbian Phones) 1 11-28-2005 16:26
7610 not charging bongiov Nokia Hardware & Hardware Repair 7 08-15-2005 18:35
7610 not charging bongiov Nokia Hardware & Hardware Repair 1 08-01-2005 17:15
7610 Not Charging after erase Faster Update WD2 & APE (Symbian Phones) 6 07-26-2005 08:55
nk 7610 not charging loverchew Nokia Hardware & Hardware Repair 1 06-28-2005 00:21
Page generated in 0.22339 seconds with 9 queries
