Old 02-11-2007, 05:05   #1 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
Lightbulb 7610 problem...restart
when i call the phone...my phone will be restart.......
Old 02-11-2007, 05:35   #2 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
check for viruses..
flash latest version...
format user area...
br
Old 02-11-2007, 05:51   #3 (permalink)
Allunlockingsource's Avatar
Member: 333439
Sonork: 100.1589101
Thanks Meter: 623
plz format userarea........................
and then flash
Old 02-11-2007, 05:56   #4 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
yes bro...i have already full format and full flash...but same too....
Old 02-11-2007, 12:32   #5 (permalink)
.:Tanveer.:'s Avatar
Member: 195957
Thanks Meter: 53
just re hot p.a and clean battery connector i tried many symbian based phones 100% tested.
Old 02-11-2007, 12:37   #6 (permalink)
mhamad-198's Avatar
Member: 437340
Thanks Meter: 35
thanks................
Old 02-11-2007, 19:18   #7 (permalink)
.:KHALIFA:.'s Avatar
Member: 275631
Thanks Meter: 408
first change battery....
Old 02-11-2007, 19:28   #8 (permalink)
Member: 374225
Thanks Meter: 41
ur set is infected with virus try format ur set n also format ur mmc if not solved then clean ur batt connector properly
Old 02-11-2007, 19:46   #9 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Thanks Meter: 10,367
If you still now in same problem.Contact me in my MSN messenger.
Old 02-14-2007, 14:21   #10 (permalink)
Member: 272972
auto restart 7610
change SD RAM IC 100%set ok
Old 02-14-2007, 15:29   #11 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
hello everbady i think usererea and mmc card format and restart pro ok 100% tested i cheak the 100 set the same pro and ever callfone is ok.(BR)
..::MR
Old 02-14-2007, 18:18   #12 (permalink)
Member: 140461
Thanks Meter: 6
Erase
Full Flasch
Format Manuel
Format Mmc Card
All Its Ok
Old 02-14-2007, 19:34   #13 (permalink)
Member: 217853
Thanks Meter: 13
first format ur phone then check without mmc if the poblem solve then format ur mmc on computer and install new files .it works . if hardware then first insert other battery for checking and also check the connecter and for short if the problem remains same means during call set goes off the rehot o replace PA .
i flashed nokia 7610s rm-354 version 7.23 problem restart but after flash 33872 Nokia Base Band 5 ( BB-5 ) 3 01-12-2010 09:15
7610 keeps restarting ian_clyde WD2 & APE (Symbian Phones) 24 02-17-2009 16:19
7610 auto restart Totul Nokia Hardware & Hardware Repair 5 08-09-2006 06:31
7610 auto restart.... desmond2727 Nokia Hardware & Hardware Repair 22 03-29-2006 01:57
Page generated in 0.29673 seconds with 9 queries
