Old 09-25-2008, 03:33   #1 (permalink)
Member: 330534
Thanks Meter: 4
7610 soutdown after 20 sec???
i've 7610 with good imei soutdown after 20 second
i flashed it after full erase and write pm but still
i made the jumper of zocus ic but no use
so whats the proplem
plz help
The Following User Says Thank You to MACAVELI For This Useful Post:
Old 09-25-2008, 04:14   #2 (permalink)
Member: 792839
Thanks Meter: 1,104
plz help
brother ... only replace uem and flash ic ... i do it before ... its work
Old 09-25-2008, 04:46   #3 (permalink)
mobilelink's Avatar
Member: 318277
Thanks Meter: 92
plz help
Mate
Chk the EMEI no ..If the EMEI is corrupted u will face the same issue..if so u will have to Write the RPL
Post results
Old 09-25-2008, 05:07   #4 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
brother 100% uem paroblam chang uem
Old 09-25-2008, 05:27   #5 (permalink)
Member: 330534
Thanks Meter: 4
if i want to put new uem what should i do
read the rpl from the phone before or what should i do????
Old 09-30-2008, 09:12   #6 (permalink)
gujjar_brothers's Avatar
Member: 558087
Sonork: 100.1579413
Thanks Meter: 332
br,, uem fault ,, change uem & write rpl ,, phone will be ok ,
Old 09-30-2008, 09:16   #7 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
ic flash problem test by me!!!
Old 10-17-2008, 20:41   #8 (permalink)
Member: 718773
Hi shake uem or change
Old 10-17-2008, 21:44   #9 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
Thanks Meter: 262
hear is corrected solution tested by me in same 7610 and 6670
good luck
The Following 3 Users Say Thank You to azez.sd For This Useful Post:
6610i insert sim and auto off after 20 sec GSMBALOCH Nokia Hardware & Hardware Repair 14 09-03-2007 17:55
6610i auto off after 20 sec GSMBALOCH Nokia Hardware & Hardware Repair 11 09-03-2007 13:37
3100 restart after 20 sec. DarkSkir Nokia Hardware & Hardware Repair 6 02-02-2006 23:37
SL55 when Dor is open phone worked IF closed powered off after 20 sec solution MaFiaaa Siemens Hardware Repair Area 7 02-27-2005 20:21
Page generated in 0.17593 seconds with 9 queries
