Old 07-10-2006, 15:19   #1 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
7610 St_lprf_if_test Failed
i have a 7610 show this ST_LPRF_IF_TEST FAILED when i use jaf to do the self test, the phone sometimes works 100% full signal with no problem but sometimes the signal is 0%.
I already change PA, i already flash the phone MCU + PPM + PM. Format user area.
Still the phone sometimes 100% full signal and sometime 0% signal.
Old 07-10-2006, 16:02   #2 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
okay, now i already try to click the repair bt, and the phone test result is ST_EXTERNAL_RAM_TEST failed and sometimes pass.
this results sometimes failed and sometimes all show pass.
May i know what is the problem.
Old 07-10-2006, 16:36   #3 (permalink)
baywalker's Avatar
Member: 260002
Thanks Meter: 8
you can reheat, reball or replace the SDRAM.
B.R.
Old 07-10-2006, 17:02   #4 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
hello sir hooi76
u r problem nokia 7610 )
sir i thimk the problem cant software its hardware
change prossaser whan full wash phone aftewr ful flash latse vertion
ok .........
Old 08-11-2006, 08:17   #5 (permalink)
Member: 68085
Thanks Meter: 5
try to rehot small flash ic
Old 06-09-2007, 17:22   #6 (permalink)
monti_908's Avatar
Member: 18262
Thanks Meter: 160
hi there friend,
"ST_LPRF_IF_TEST ", this test is for bluetooth cbus, i think u should change or rehot bluetooth ic,
post the result
moni
help 7610 ui failed juniour member Nokia Hardware & Hardware Repair 5 08-31-2007 12:15
7610 stratup failed and off navin71 WD2 & APE (Symbian Phones) 5 08-10-2007 11:06
7610 startup failed vipul manchanda Nokia Hardware & Hardware Repair 8 08-19-2006 04:48
bluetooth 7610 repaire failed erorr 1100 by tornado???? semo Nokia Hardware & Hardware Repair 1 12-07-2005 08:22
Page generated in 0.25941 seconds with 10 queries
