Old 09-06-2008, 10:33   #1 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Unhappy 7610 white sacreen calling etc ok
hi everybody nokia 7610 white screen first of all i have change .
[1] L C D
[2] Display ics
[3] display connector
[4]uem and upp rehot but stile same ....................................
plz help me i m very confused what should i do ?
Best Regards.
I K R A M B U T T
Old 09-06-2008, 11:12   #2 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
dear bra .....u all rady everything try...but i have get 2 set same like u problem....and i get sucess check boot ic near cleen there and rehot that section may be u problem solved
Old 09-06-2008, 11:13   #3 (permalink)
Rizal Arsyad Dini's Avatar
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,155
check voltage at the connector...
if lost... it made blank display
Old 09-06-2008, 11:39   #4 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
[1] L C D
[2] Display ics
Best Regards.
I K R A M B U T T
this will help you.
By pupaji at 2008-09-06
The Following User Says Thank You to pupaji For This Useful Post:
Old 09-06-2008, 11:50   #5 (permalink)
Member: 364745
Thanks Meter: 719
THX FOR REPLY BRS i alredy trying rehot boot ic and also check br pupaji........ your solution ......
my problem is stile same ....................
Old 09-06-2008, 11:51   #6 (permalink)
Member: 364745
Thanks Meter: 719
Old 09-06-2008, 15:51   #7 (permalink)
Member: 39251
Sonork: 100.1618715
Thanks Meter: 6,155
have u check the voltage on LCD Conector???
n81 white display calling ok plz helpme subbu_92143 Nokia Base Band 5 ( BB-5 ) 1 11-09-2009 14:47
7610 white screen all calls incoming outgoing flashed many version still white screen GSMBALOCH Nokia Hardware & Hardware Repair 7 06-01-2009 20:54
Samsung J600 white screen...... Calling is OK amol_sm SWIFT Platform 3 09-17-2008 18:05
nokia 6600 WHITE LIGHT. INCOMMING AND OUTGOING CALLS ARE OK. shahi Nokia Hardware & Hardware Repair 3 12-17-2007 07:30
7610 withe sacreen meeza_84 WD2 & APE (Symbian Phones) 0 05-16-2007 14:42
Page generated in 0.21624 seconds with 10 queries
