Old 11-17-2010, 05:45   #1 (permalink)
Crazy Poster
Member: 743236
Thanks Meter: 4
Question 7610s full short
7610s full short at battery points on + & - how can i findout the fault that which component may be short please help
Old 11-17-2010, 05:46   #2 (permalink)
Member: 410217
Thanks Meter: 44
remove the network pf & chek it....
Old 11-17-2010, 06:34   #3 (permalink)
Crazy Poster
Member: 743236
Thanks Meter: 4
thanks viral123 i had opened L 2070 (L 2900 ) in the schematic there is mistake (one coil having two numbers ) its ok thanks
Old 11-17-2010, 08:21   #4 (permalink)
Member: 1443421
Sonork: 100.88335
Thanks Meter: 11
dir brather this is simpel short findout [1] any mobile battery and open internal battery circuit and direct 3.7 volt connect mobile battery connecter just 10 to 5 seceond an look where is hit and remove this part 1000000000% solved no tension
The Following User Says Thank You to B.SAHA For This Useful Post:
Old 11-17-2010, 14:09   #5 (permalink)
Crazy Poster
Member: 743236
Thanks Meter: 4
i tried same thing before findout short i had given 1.8 to 2 volts to battery connector but n 1450 L 1452 and surrounding area gets heat but when viral123 replied me then i tried
opened L 2070 (L 2900 ) in the schematic there is mistake (one coil having two numbers ) through this coil supply goes to R F ic so RF is short
The Following User Says Thank You to lasertalk_prem For This Useful Post:
Old 10-09-2011, 14:44   #6 (permalink)
Member: 418861
Thanks Meter: 5
7610s drigram and sort mark plzzzzzz help
Full Flash 5130 V05.61 nokia_flash Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-03-2011 15:38
Wanted 6130 4.02 full backup Pls Read Charly Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-06-2001 05:12
6150 Full Flash , Help AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-03-2001 13:34
Full flash for 6110 v5.24 needed tcfx44 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-30-2001 14:04
NOKEY BOX FOR SALE - FULL Zorz Main Sales Section 0 12-05-2000 10:56
Page generated in 0.14633 seconds with 9 queries
