Old 07-21-2003, 21:22   #1 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
7650 battery run out fast
Hi,
I have this 7650 handset anytime the battery is fully charged, just make two or three calls and the battery is flat and phone switches off.
Please help with ideas.
Thank you in advance.
eko
Old 07-22-2003, 01:26   #2 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Please check phone current consumption... using Regulated power supply... or check battery contacts for Leakage. If so.. try to remove coil suply to PA.. and test for leakeage.. If leakage gone then you have shorted PA. Replace it.
Old 08-09-2003, 19:06   #3 (permalink)
Member: 14716
Thanks Meter: 15
Hi, try to start Bluetooth, if you got "sistem error" you must remove or replace BT module. I had once same problem and I was just removed that module. Phone work fine.
nokia 3310 battery running down fast gbada Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 15 03-20-2017 20:02
D900 battery runs out at 4hours! adrenaline79 SWIFT Platform 6 04-28-2009 15:39
D900 battery runs out at 4hours! adrenaline79 Trident/AGERE Platform 0 04-25-2009 06:10
D900 battery runs out at 4hours! adrenaline79 Samsung Hardware Repair 0 04-24-2009 11:48
on nokia 3310 battery run out too fast. when talking it powers off. sat Nokia Hardware & Hardware Repair 2 08-30-2001 08:07
Page generated in 0.13407 seconds with 9 queries
