Old 10-18-2004, 12:50   #1 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
7650 display problem
hello friends, i have 3 7650 with same problem,
the problem is that when i switch on the phones the lights comes on,
but only black tiny horizontal lines show on the lcd,
i have changed more than 5 trusted lcd no result, so i have ruled out lcd as the problem, can someone tell me where this problem is located,
thanks,
gibso.
Old 10-18-2004, 16:25   #2 (permalink)
Member: 63385
Thanks Meter: 3
Try to flash. Maybe not LCD problem...
Old 10-19-2004, 08:07   #3 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 60
7650 problem
thanks,
gibso.
have you try to make a call? if you can make a call, it mean LCD problem but if you can't make a call, it is sofware and hardware problem, so you must try to ceck sofware fist by flash it using griffin without detect phone, why griffin? cause griffin more powerfull to flash this phone, if you can't flash or griffin give you error it mean hardware problem, usualy is Flash IC or Memory...
regards
Old 10-19-2004, 13:25   #4 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
thanks for your ideas guys justincase i forfoti've already flashed phone both with prodigy and twister, my lcd's are also 100% good,
thanks again for your care, more ideas pls
gibso.
Old 10-19-2004, 13:55   #5 (permalink)
btl
btl's Avatar
Member: 50389
Thanks Meter: 36
then check the lcd contact maybe one if the pins is of just try resoldering it maybe that could help
Old 01-15-2006, 14:11   #6 (permalink)
Member: 64002
Thanks Meter: 11
i have same problem. help
Old 08-20-2007, 14:13   #7 (permalink)
Member: 406679
My Nokia 7650 Is Working Properly But Lcd Lights Are Not Getting On . Can Any One Solve This Problem. ?
Old 08-20-2007, 20:00   #8 (permalink)
Member: 416676
Thanks Meter: 5
[QUOTE=rufi1711;2653760]My Nokia 7650 Is Working Properly But Lcd Lights Are Not Getting On . Can Any One Solve This Problem. ?try to replace light booster
7650 display problem gibso Nokia Hardware & Hardware Repair 5 08-04-2004 21:11
Looking for info about Nokia 3650/7650 Display ncmaothvez WD2 & APE (Symbian Phones) 3 03-18-2004 08:30
Looking for info about Nokia 3650/7650 Display ncmaothvez GSM Programming & Reverse Engineering 0 12-04-2003 19:14
Looking for info about Nokia 3650/7650 Display ncmaothvez WD2 & APE (Symbian Phones) 2 12-04-2003 19:11
7650 Display SW Version m4tt8 WD2 & APE (Symbian Phones) 7 11-20-2002 23:58
Page generated in 0.28732 seconds with 8 queries
