05-29-2003, 01:35 | #1 (permalink) |
Junior Member Join Date: Mar 2003 Location: Philippines Age: 53
Member: 23784 Status: Offline Thanks Meter: 0 | 7650 Hardware or Software Probs... Best regards, BisoOY |
05-29-2003, 17:10 | #2 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | hi,, first check that 7650 power on switch ! as long as your phone get bar of charger plug, then it mean , alomost MCU /UEM working! local mode will not display "word" in LCD ! Willy |
05-30-2003, 01:27 | #3 (permalink) |
Member: 23784 Status: Offline Thanks Meter: 0 | 7650 @ willy, nice idea mate, I'll check the power switch first if it is working? Is it possible nothing displays on the srcreen ("local mode") when I tick phone detect on griffin, if my power switch is not working? best regards, BisoOY |
05-31-2003, 01:19 | #4 (permalink) |
Member: 23784 Status: Offline Thanks Meter: 0 | 7650 Problem Solved........ @willy, poblem solve when I checked the power switch, it has no continuity If I press the middle part. Phone now works. best regards, BisoOY |
06-22-2003, 17:52 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | have simialr problem changed power switch now this one will pwoer on by itself when i isnert battrey and after some 30 seconds powers off and back on. it had water damage. any hints what i can search for? thanks al |
02-03-2004, 18:57 | #9 (permalink) |
Junior Member Join Date: Feb 2004 Age: 48
Member: 51886 Status: Offline Thanks Meter: 0 | Hi I got a similar problem. I plug the AC charger and phone shows on LCD the "NOKIA" word and then the charging icon. And that is as far I can get. I press different buttons and the only thing that happens is the light turns on. I though it was the power button but if I press it while charging, the LCD light comes on so I guess that is not the problem, isn´t it? Any hint on what could it be? Please help. Ed |
02-03-2004, 19:32 | #10 (permalink) |
Member: 51886 Status: Offline Thanks Meter: 0 | OK, I'm not familiar with this phone, is it normal that while the AC charger is connected the phone reacts (LCD light comes on) to any button I press (or opening the phone)? If I unplug the charger, the phone does absolutely nothing. Could someone cofirm this? |
02-04-2004, 04:50 | #11 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Sun Age: 44
Member: 4021 Status: Offline Thanks Meter: 782 | check the continuity of your power switch, i think its faulty.... as long as the charging indicates it means the sw and uem is ok... double check the switch before doing anything else |
02-05-2004, 00:52 | #12 (permalink) | |
Member: 51886 Status: Offline Thanks Meter: 0 | Quote:
Ed | |
04-28-2005, 03:07 | #14 (permalink) |
Junior Member Join Date: Jul 2004
Member: 75465 Status: Offline Thanks Meter: 0 | i'm in a similar situation with a 7650 - power switch just suddenly stopped responding! plug charger in and "nokia" appears and the escalating battery symbol appears. Press any button and lights turn on, open keypad light turn on, close keypad light turn on etc, but power button does not work at all! I know the button itself is just a tiny little component, but will probably cost loads to replace just to be awkward, but where DO you get them from? |
04-28-2005, 06:12 | #15 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
change flexi cable and power swicth, all slove (can charging but no power on) | |
Hardware of software prob..PLZ HELP | Saaduk | Siemens Hardware Repair Area | 16 | 08-15-2003 02:08 |
7650 Hardware or Software Probs... --2 | kulibin | Nokia Hardware & Hardware Repair | 6 | 06-04-2003 09:17 |
65656565 funny IMEI,with Contact Service on Screen, is it Hardware or software Problm | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 23 | 10-13-2002 15:00 |
Hardware or Software? | -=G3=- | Hardware Equipments for GSM | 0 | 01-25-2002 00:14 |
M30 Hardware or software problem? | Pandemonio100 | x1x to x45/x50 | 0 | 07-11-2001 19:43 |
