03-06-2004, 10:28 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: Portugal Age: 42
Member: 12207 Status: Offline Thanks Meter: 2 | 7650 low battery when place call Tnx... XARiUS |
03-07-2004, 21:53 | #3 (permalink) |
Freak Poster Join Date: Dec 2003 Location: E G Y P T Age: 47
Member: 45635 Status: Offline Thanks Meter: 20 | reflash your phone using griffin box with v 5.6 , user code , set factory setting , format limited , test then format user area . if have a power faileur reflash your phone again without format user area. if still the same change PA ............ |
05-30-2004, 19:16 | #4 (permalink) |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | there is VDR inside charging part of your cell phone, try to find it in service manual and remvoe it or change it. this VDR decrease battery voltage for CPU, as the CPU get a low battery the message will diplay in screen. have fun |
11-10-2004, 20:38 | #8 (permalink) | |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | Quote:
@kki | |
01-10-2005, 13:38 | #10 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Hellas Age: 47
Member: 83893 Status: Offline Thanks Meter: 1 | ADC-offset over limits: Inspect BSI line, connectors (hotbar and board to board connector) and components in it (Varistor R008, EMI-filter Z383, Pull-up resistor R384). If these are OK, change UEM. BSI Gain over limits: Inspect BSI line, connectors (hotbar and board to board connector) and components in it (Varistor R008, Capacitor C002, EMI-filter Z383, Pull-up resistor R384). If these are OK, change UEM. Btemp Gain over limits: Inspect Btemp line, connectors (hotbar and board to board connector) and components in it (Varistor R006, Capacitor C010, EMI-filter Z383, Pull-up resistor R383). If these are OK, change UEM. Vbatt offset and Gain: Inspect Vbatt lines and component in it. Vchar over limits: Inspect components which are connected Vchar line: Filtering capacitors C005, C006, C011, TVS V009, L001 and Fuse F001. If those are OK, Change UEM Ichar over limits: Inspect components which are connected at Vchar line: Filtering capacitors C005, C006, C011, TVS V009, L001 and Fuse F001. If those are OK, First change current sense resistor (R190), if calibration is not still successful change UEM. these are clopy pasted from the service manual i suspect r008 should be faulty i have a similar problem and cannot find a component like the one in question has nybody changed from another model to this one and solved problem? thanks and i hope somebody found it usefull.. |
6120c when I call show low battery | Elias Khan | Nokia Hardware & Hardware Repair | 6 | 11-18-2009 07:49 |
6234 after one call low battery and damage and expand the battery cell pplz help | asif_ae | Nokia Hardware & Hardware Repair | 2 | 05-12-2009 06:01 |
6630 empty battery when making calls | kopotan bahr | Nokia Hardware & Hardware Repair | 13 | 12-23-2008 06:07 |
NOKIA 1100 2300 2600 2100 3310 3315 etc. low battery during call and disconnect | tarikalikhan | Nokia Hardware & Hardware Repair | 6 | 10-09-2007 08:32 |
8210 low bat when calling | emix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-05-2001 15:25 |
