8210 blank LCD with good LCD and new Dear Friends............ how to repairer 8210 blank lcd I was change with new and good lcd regards, uwenk98 |
I already check from LCD Interface : 1(2.8v),2(0),3(0),4(2.8v),5(2.8),6(0),7(0),8(0),9( 2.8v) the problem is from 6(0) he must be 6(2.8v). I check from circuit diagram 6points(ROWLCDD/C) connect to cpu e3pins where I must make jumper is???????? Please help regards, uwenk98 |
Rubber You have to change a peace of rubber at the back of the display i had the same problem but its fixed now i turned the rubber backwards and it was fixed |
NO MAN.......................!!!!!!!! the LCD and RUBBER is very good conditions I already said my ROWLCDD/C(pins6 on board) not connect to CPU pins E3 and I dont know to where I must make a jumper by wire. |
pin 6 C/D (LCDCDX) goes to CPU pin ROW5 u can find SELFTEST points J230 (GND) and J229 (ROW5) maybe not at all versions of PCB got them... check out service manual |
OK friend I will try it thanks a lot |
