Old 11-30-2004, 16:04   #1 (permalink)
Member: 77704
8210 charging problem
Hello, I have 8210 who charging using only ACP-9E. Using other chargers (ACP-7, ACP-8E) no charging (nothing happends). Chaps IC changed - not results. Please help.
B.R
simono
Old 11-30-2004, 16:12   #2 (permalink)
garmani's Avatar
Member: 43758
B.R
simono
Hi,what about small ikon of charging is blinking or not...did you clean contacts well...?
g******
Old 11-30-2004, 16:18   #3 (permalink)
Member: 77704
No blinking, no message "NOT CHARGING". All is ok when uing ACP-9E (from 9110 Communicator)
B.R
simono
Old 11-30-2004, 18:15   #4 (permalink)
Member: 38922
Thanks Meter: 35
some models hate the faster chargers maybe in your case.
GreetZ
Old 11-30-2004, 18:31   #5 (permalink)
Member: 79823
Thanks Meter: 26
i think cyber is right the best charger for 8210 type of fone is acp 12 otherwise use the normell chager adaptor type acp7E that is the best
daanish
Old 12-01-2004, 13:41   #6 (permalink)
garmani's Avatar
Member: 43758
Hi,
I think in this case is no point to talk about charger we have to know what was before changing charging circuit ...problem is somewhere else...
g******
Old 12-01-2004, 23:33   #7 (permalink)
badi's Avatar
Member: 11945
Thanks Meter: 76
B.R
simono
ccont for sure,change it.
good luck.
Old 12-01-2004, 23:54   #8 (permalink)
Member: 38922
Thanks Meter: 35
99% Most cases: BATTERY defective, Charger false (or defective), FUSE; CHAPS, CCONT.
GreetZ
8210 CHARGING PROBLEM Weller Nokia Hardware & Hardware Repair 11 06-07-2013 16:38
8210 Charging Problem fonetech Nokia Hardware & Hardware Repair 3 01-26-2003 06:31
8210 charge problem .::AkhavanGSM::. Nokia Hardware & Hardware Repair 4 12-17-2002 07:52
8210 charge problem. Repair solution Pk2GSM Nokia Hardware & Hardware Repair 0 11-19-2002 16:56
PLEASE help with 8210 charge problem HooGSM Nokia Hardware & Hardware Repair 1 05-24-2002 00:41
Page generated in 0.15279 seconds with 9 queries
