04-06-2002, 20:35 | #1 (permalink) |
Junior Member Join Date: Feb 2002 Location: uk
Member: 9742 Status: Offline Thanks Meter: 0 | 8210 dead This is what i think hapened to it: Dropped in water then this girl thought it was no good Somehow it then had oil spilt over it also a number of problems like the keypad and elastomer were a bit dodgy before all this happened I would just like some help on how to fix this, I have tried cleaning it with meths in a ultasonic cleaner but no luck also when i try to flash it in rolis 4.77 i select 8210 and when it says power on the phone, if i press the power botton it reads it wifin a second as if theres no software on the phone but wont let me write any sofware to the phone ***also when i try to flash new software to it, it says Preloader error, check cables, contacts etc..... thanks in advance Matt Last edited by matttwine; 04-06-2002 at 20:41. |
04-08-2002, 04:32 | #2 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi Before using any software, you should clean it, with ultrasonic cleaner or with some chimical cleaner ( for electronic use ), then rehot the bord. If your phone does'n accept any softaware connection, be sure to test first your cable with an other phone, to be sure that the probleme is from the cable or the soft or the phone or more than one of them. test this and give me the result good luck |
8210 dead after alc bath! | Erci | Nokia Hardware & Hardware Repair | 0 | 02-21-2002 02:23 |
8210 dead set problem | ryumahon | Nokia Hardware & Hardware Repair | 9 | 02-15-2002 07:35 |
help 8210 dead | toddster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-24-2001 07:17 |
8210-dead-STOLEN-HOW CAN i READ THE PHONES BOOK? | cosmo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-04-2001 22:59 |
nokia 8210 dead after flashing | RanGerZzz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-09-2001 01:50 |
