Old 05-14-2002, 18:39   #1 (permalink)
Pandemonio100's Avatar
Member: 3381
Thanks Meter: 1,164
8210 don't power on.....but charge ok
Hi friends i have one 8210 whit this problem, if i connect phone to travel the phone charge ok, but if i try to power up don't switch on, i think phone is dropped in water, i have ceck for oxid but only under the display there is a lot of oxide, i have changed also power switch, R118 and other cap near CCONT, tested voltage output around 3.50v.
Tanks for help.
Old 05-14-2002, 20:38   #2 (permalink)
Member: 7062
Thanks Meter: 121
u don't have to to all that just u must to check the start up group the capictor under the on/off switch so if u changethe switch key
u must have a working board...no more
Old 05-14-2002, 23:24   #3 (permalink)
Member: 3381
Thanks Meter: 1,164
ceck also cap near swithc canged nothing to do.
Old 05-15-2002, 02:21   #4 (permalink)
Member: 10046
have you tried cleaning the board?
last time i cleaned one i used switch cleaner (one which evaporates and doesnt leave a residue) and a very old soft toothbrush to work the stuff in, then flushed it under running water, after that i left it on the side with a hairdrier (dont laugh ) to make sure it was thoroughly dry before putting it back together
Old 05-15-2002, 04:13   #5 (permalink)
Member: 3381
Thanks Meter: 1,164
Yes i have also clean the board whit isopropil alcool, if you would see it seems new
6600 not power on but charge ok pratik_1111 Nokia Hardware & Hardware Repair 12 08-25-2009 07:16
gx 25 no charging, no power on but flash ok the sorrow Sharp 4 08-29-2007 21:39
V3x no power on but charging ok gattus Motorola Hardware Repair 15 07-21-2007 08:25
6600 not power on but charge ok Ramiz Nokia Hardware & Hardware Repair 7 03-14-2006 18:43
A800 no power on but charging ok Cat10 Samsung Hardware Repair 13 03-06-2005 13:58
Page generated in 0.26439 seconds with 8 queries
