Old 09-01-2002, 19:04   #1 (permalink)
.:*CHENNAI GSM*:.'s Avatar
Member: 8587
Thanks Meter: 4
8210 low standby
Mates
This handset has this problem after changing the LEDs . Can talk only 2 mins after that battery empty warning and switches off. Tried changing PA , full flashed , repaired IMEI and calculated faid . No Improvements . Can anybody help me.
Regards.
Old 09-01-2002, 23:08   #2 (permalink)
george gsm's Avatar
Member: 14200
Sonork: Sonork id
Thanks Meter: 117
hello abibaby,
blue leds eat more energy. change green back
geo
Old 09-01-2002, 23:39   #3 (permalink)
Member: 1060
Thanks Meter: 10
Re: 8210 low standby
abibaby
i guess it happen after you replace keyboard side led with hot air ?
if yes, try to check at CCONT and parts around it
Willy
Originally posted by abibaby
Mates
Regards.
Old 09-05-2002, 20:00   #4 (permalink)
Member: 8587
Thanks Meter: 4
Dear Willy
Yes, I did changed two of them with my hot air ****er since I mixed the colour of the led's and which didn't worked.Can you be more precise on which components do I need to check.
Thanx
Regards
Old 09-05-2002, 21:06   #5 (permalink)
Member: 1060
Thanks Meter: 10
HI Abibaby,,
try to make energy measurememt with wintesla , set higher voltage for low battery alarm !
then change value R311, R310 ,, make it higher too ( it will let your led not much bright) !
Willy
Dear Willy
Thanx
Regards
Old 09-06-2002, 07:40   #6 (permalink)
Member: 8587
Thanks Meter: 4
Dear Willy
Do you have the schematic of the service battery, If you do please send it to me on my mail id.
I heard that the schematic is very simple .
Thanx in advance.
Old 09-06-2002, 18:31   #7 (permalink)
Member: 1060
Thanks Meter: 10
HI Abibaby,,
it is easy to build a "replace" service battery for your phone,,
just put a 22kohm from BSI to GND,, it can make phone power on,,
but not for energy measurememt !
Willy
Dear Willy
Thanx in advance.
Old 09-07-2002, 15:54   #8 (permalink)
Member: 9828
Thanks Meter: 2
willy, do you have scheme for wintesla energy management service battery
thnx in advance
Old 09-07-2002, 20:08   #9 (permalink)
Member: 8587
Thanks Meter: 4
Dear Willy
Thanx friend and hope to get your expert advice in these following questions too.
1.How can I set higher voltage for low batt alarm in wintesla . Please explain the menu process in wintesla friend.
2.What for is the energy management process in wintesla ? If it is for power recalibration in eeprom , will it make any difference if I write a virgin eeprom.
3.I am not able to connect only 3310 to my wintesla (5110 and 8210 working fine)even after installing the NHM-5 DLLs. My system is giving "Illegal operation performed" error if I am trying to connect a 3310 handset to Wintesla. Could this be a problem with the auto switching cable I am using with 3310?
Thanx in advance
Regards
Old 09-07-2002, 22:23   #10 (permalink)
Member: 1060
Thanks Meter: 10
Abibaby
<p><A href="http://imagehost.auctionwatch.com/bin/viewimage.x/00000000/demetan1/energy.jpg"><img src="http://imagehost.auctionwatch.com/bin/imageserver.x/00000000/demetan1/.mids/energy.jpg"
</font></A><br>
when it say give power supply 10.5 V, this is time, you can adjust it to 10.7V
i have no idea how to build energy calibration service battery!
Willy
Old 09-08-2002, 16:05   #11 (permalink)
Member: 7062
Thanks Meter: 126
hey hey .. please willy try to b simple in ur replys we r not qauthorised services points we all have simple tools .. we haven't even enginreeings services hints as u have .. try to give us the right simple way please
Old 09-08-2002, 16:18   #12 (permalink)
Member: 1060
Thanks Meter: 10
Raheeeeb,
before ,, i just use original service battery to provider power via SCB 3 into charger plug of phone . never try to see what is it voltage from service battery to phone ! (may be you can tell us too) !
and i do not think, i can biuild (DIY) a service battery for energy calibration service battery , Sorry
Willy
Old 09-08-2002, 16:33   #13 (permalink)
Member: 7062
Thanks Meter: 126
sorry can u explain wht u mean by SCB 3 into charger plug of phone if u please and if u can help more to let us know how to make on like it
Old 09-08-2002, 16:51   #14 (permalink)
Member: 1060
Thanks Meter: 10
Raheeeeb,
SCB 3 ,,it is DC-DC cable ONLY,,
one side plug to phone charger connector
others side plug to original service battery
and it use for supply charger to phone for energy and charger calibration
Check your ICQ list ,,
thanks
Willy
sorry can u explain wht u mean by SCH 3 into charger plug of phone if u please and if u can help more to let us know how to make on like it
Old 12-23-2002, 20:30   #15 (permalink)
qba
Member: 16443
For me i get an Illegal operation when i try with Nokia 8210. I have not tried other phones, i will do so now
3310 low standby TO WILLY ::.::HITGSM::.:: Nokia Hardware & Hardware Repair 2 01-25-2004 09:17
Motorola v3690 low standby time kovacn2 Motorola Old Legacy (EMMI) 0 12-12-2003 21:20
Low standby problem...help~ mild7 Sony Ericsson 10 06-23-2003 11:19
s35 low standby szakiz Siemens Hardware Repair Area 0 06-03-2003 20:45
3210 low standby time battery easily drain??? eureka8888 Nokia Hardware & Hardware Repair 2 05-07-2002 11:01
Page generated in 0.26015 seconds with 9 queries
