09-07-2002, 13:57 | #1 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Palestine Age: 61
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | 8210 with Mbus Error Please , I need your help with Nokia 8210 , it was dead then I flash it and it's working , now I need to make Authority ID , but i can't make a connection to the phone nothing wrong with the cable I try several times with several program & still getting Mbus error , can you help me ? Best Regards Laser |
09-07-2002, 17:58 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 8210 with Mbus Error Laser Check R203 4.7kohm, this is connect to Vbb pull high for MBUS others, problem from MCU! Willy Quote:
09-08-2002, 10:06 | #3 (permalink) |
Member: 9763 Status: Offline Sonork: 100.1655983 Thanks Meter: 2 | 8210 Mbus error Hi Willy , Thank you , R203 is 4.7 Kohm , any other way to set Auth ID for this phone or do I have to change the MCU , can I use MAD 4370687 v16 instead of MAD 4370593 v11 ? it's a glue MAD is it possible to change it ? Best Regards Laser |
09-08-2002, 10:58 | #4 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 8210 Mbus error Laser, before you replace MCU, you have to make sure, that PULL HIGH VBB to R203 is provide ! since you can flash phone, i think, MBUS just not pull high only for this case , becasue mbus is clock when you flash phone ! Rom 6 MCU can be use at 8210 , then you need flash V5.30 up Willy Quote:
12-07-2004, 08:08 | #6 (permalink) |
Junior Member Join Date: Dec 2004
Member: 96152 Status: Offline Thanks Meter: 0 | 8210 totaly dead good day! I also have similar problem. I have a 8210 unit came to me totaly dead. I already changed ccont. reflow cobba, hagar but still the same. I flash it with twister and receive M-bus error repowering mobile.when i try to flash it phone cannot boot it has a click sound 2x when i try to flash. can someone help me with this problem. many thanks... I'll be glad if someone could... Last edited by bon_roie; 12-07-2004 at 08:16. Reason: add information |
dct4 flasher mbus error | gsmsikar | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 08-21-2003 12:28 |
CHeap Flasher MBUS error | AlQuds | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 06-30-2003 23:41 |
Error Using Knok 22 with mbus cable | dytln | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-17-2002 03:18 |
8210 Mbus Error | Laser | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-12-2002 08:28 |
8210 and MBUS? | pavlin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-29-2001 15:51 |
