Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 06-25-2001, 08:41   #1 (permalink)
Member: 4188
Cool 8210 no network - How to repair it ?
I've a 8210 that cannot find any network. The error message is " No Network Coverage ".
This phone has not been flashed before. If do a network search, it says " No Network Found". How to repair it?
Old 06-25-2001, 17:45   #2 (permalink)
Member: 3876
Post
change duplex 8103.
Old 06-25-2001, 18:38   #3 (permalink)
Member: 4873
Post
try to clean cobba, z600, z700 area with lighter fluid or some flux and **** some hot air... medium temp, i have fixed this before, best regards
by the way, have the phone ben dropped before this occured?
Old 06-26-2001, 05:33   #4 (permalink)
Member: 4188
Cool
Originally posted by trafix:
<STRONG>try to clean cobba, z600, z700 area with lighter fluid or some flux and **** some hot air... medium temp, i have fixed this before, best regards
by the way, have the phone ben dropped before this occured?</STRONG>
As far as I can tell, no , however I'm willing to try anything.
As for your advice, I'll try, I've cleaned the Hagar but it is of no use.
Unlockphone.
Old 06-26-2001, 05:38   #5 (permalink)
Member: 4188
Post
Originally posted by rcgoel:
<STRONG>change duplex 8103.</STRONG>
What's the part list number for the chip?
Old 06-29-2001, 22:42   #6 (permalink)
Member: 3248
Post
hi.
i had a 8210 which got network sometimes and somtimes not.
i tooke it to nokia service center they tell they fix i test it the same problem very bad network. i take it back to them they said they gonna do their best then they told me after hard work they don;t have solution for this prob.
so guys what do u think???
can anyone tell me soltuion for it.
the nokia servce center they upgraded the sw and still the same prob.
Old 07-02-2001, 02:32   #7 (permalink)
CellM@n's Avatar
Member: 3194
Post
Have you try to replace the VCO , on the left side in metal Cover ( FDK ... )
Try it.
I 've made it 3 times before.
Rgds
Old 07-02-2001, 23:11   #8 (permalink)
Member: 3248
Post
hi BBand,
this solution is it for my problem???
if yes plz can you be more specific???
thaks a lot.
take care
bye
Old 07-03-2001, 02:29   #9 (permalink)
CellM@n's Avatar
Member: 3194
Post
Try to replace part that labeled FDK ..., its place is on the left side ( metal ). I cant give you specific part because i dont have service manual here.
The second solution, antenna switch is most common problem in 8210.
Take care too 4 u
Mail me if u want
Note : Any Siemens Service Manual???
Rgds
Old 07-11-2001, 16:11   #10 (permalink)
themobileking's Avatar
Member: 5072
Post
HI
BBand is right
themobileking@yahoo.com
Old 07-12-2001, 16:18   #11 (permalink)
Member: 3248
Post
thnaks guys for help
i found it,
can you tell me plz where can i found from these chip?
Old 07-13-2001, 01:08   #12 (permalink)
Hanukkah's Avatar
Member: 5246
Post
Originally posted by zbomberman:
<STRONG>hi.
</STRONG>
If i'm correct.. intermittent signal problems like this is from the antenna switch beside the Power Amps. anyone more experience wish to correct me?
Old 07-13-2001, 11:45   #13 (permalink)
Member: 3248
Post
this one that you r saying about is known i think and we try it but it is not working at all.
so i have to do as they advised me to replace the fdk chip on the board when i will get one i am going to post my result here.
thanks all of you guys for ur answers.
take care
bye
Old 07-14-2001, 11:38   #14 (permalink)
Super Moderator
Pandemonio100's Avatar
Member: 3381
hI i have resolved one canghed the PA module, on test set when the power amplifier is low all Nokia not recognized or not register the network.
This is the path of received gsm signal:
Antenna,Diplexer(Z503),TX/RX switch(Z504),PCN filter(Z602),CRFU3(Mixer N600), LC 187 Mhz filter(L604), CRFU3 (Mixer N600), SAW filter 71Mhz (Z700), SUMMA (N700), 13MHz filter (Z701), SUMMA, COBBA (N200).
Old 07-15-2001, 00:17   #15 (permalink)
Member: 3248
Post
hi guys i tried to replace the fdk it didn't work the same problem some phone work with this solution others don;t.
dear Pandemonio100
i didn;t understand what you mean can you explain more to me.
thanx in advance.
nokia 3220 has network problem how to repair it shakil143 Nokia Hardware & Hardware-Repair Area 2 10-30-2009 15:36
3310 no network - How to fix it? du Nokia Hardware & Hardware-Repair Area 19 08-10-2009 11:56
3650 has no PM, How to repair it 123567890 WD2 & APE (Symbian Phones) 15 04-17-2008 00:16
t630 no network , how to,resolve it please leroi UFS2 + UFS3-Tornadoflasher 4 02-17-2006 08:33
Please ĦĦĦĦĦI need Help For t191 Always beeping!!!! and no way found to repair it. DREAMGSM ODM (Original Design Manufacturing) 0 08-22-2002 13:27
Page generated in 0.45104 seconds with 11 queries
