Old 05-02-2004, 04:59   #1 (permalink)
Member: 12207
Thanks Meter: 2
8210 No RX, but good TX
Hi! I've got 2 8210 that have good tx (at least i think they have), but no RX! I say it has good tx, because when i phones on, and look at the netmonitor, i see in the tx part '* 5', so, it's transmitting, and rx stays in 0! Oh, one interesting thing is that if i remove T700 (see attatchement) i get rx, but now i won't get any tx, and when turn on phone, it gets sinal, and then disapears! I've changed PA (3 times), Diplexer (2 times), HAGAR, CCONT, COBBA! Oh, also changed T700!
What can i do more? What coud be the problem? I'm really pi**ed off with those 2...
Tanks in advance
XARiUS
Old 05-02-2004, 09:04   #2 (permalink)
Member: 44658
Tanks in advance
XARiUS
Hi
What program you using to tune the phone? Wintesla? Whats RSSI?
Have you probed the phone at all? RX path going into the Hagar? (using spectrum analyser)
If your still having trouble, change everything on the RX path going into Hagar.
Check Hagar voltages to see that hagar is turned on.
/ or /
probe RX IQ's with oscillosope R530..
Thanks
Old 05-02-2004, 10:45   #3 (permalink)
Member: 32182
Thanks Meter: 2
Tanks in advance
XARiUS
you can not make a call that mean the tx part is failed!
so in this case you have to check tx line to see if there is signals if yes check L103 near PA n replace it ! then post the result !
Old 05-02-2004, 18:12   #4 (permalink)
Ashwani Gaur's Avatar
Member: 2822
Thanks Meter: 150
First confirm your Phone Fault, its simple as follow:-
(1) Put working Sim in ur phone.
(2) Turn On Phone
(3) Goto Menu / Network Selection
(4) Choose Mannual mod
if ur PHONE finds All Available Networks in ur area, than ur SURE that Rx Path is OK.
Than if ur request for LogIn Failed it means that Tx is Faulty.
WBR
Ashwani Gaur
Old 05-02-2004, 18:25   #5 (permalink)
Member: 7168
Thanks Meter: 3
thanks for ur replay
Old 05-03-2004, 06:51   #6 (permalink)
Member: 12207
Thanks Meter: 2
Hi to all! Thanks to all your replies!
@Engineer
Wintesla RSSI stays near -96! Don't have a lot of material to make tests! Only have a multimeter! So i cannot probe a lot of things!
@hoangminhtam
I can't make a call! Oh, if i remove that L103, i can get network, but for a little time only! and netmonitor gives me a value for Rx, but not for TX!
@Ashwani Gaur
Nope, i can't find none network!
@all
It seems that if i take both parts (RX,TX) are functioning. As i said, i'm using just netmonitor to diagnose this! If i disconect anything from tx line i will have rx, but if i reconect, exchange, or whatever i do, i will get tx, but not rx! so i can have both in separate, but not at the same time! this is no good! lol!
Thanks in advance
XARiUS
Old 05-05-2004, 17:14   #7 (permalink)
Member: 2822
Thanks Meter: 150
[QUOTE=XARiUS]Hi to all! Thanks to all your replies!
@Ashwani Gaur
OK
Now first bypass Ant SW and see if u get normal RX.
if not
Change 26 Mhz Xtal
if still no RX or network than
First Reheat Hager if it works than OK if not
Change Hager
still problem same than
First Reheat Cobba if still no network Change Cobba.
WBR
Ashwani Gaur
3220 no network help me,no rx no tx ,help me shivam4you Nokia Hardware & Hardware Repair 1 03-09-2009 07:37
solution on 8210 no power but charging and flashing due to water damaged!!!!!! andrew14 Nokia Hardware & Hardware Repair 0 02-02-2005 02:20
8210 no network but PA have very hight temperature. micmac Nokia Hardware & Hardware Repair 3 11-26-2002 04:19
6310 No Signal,good Tx,rx LYRE Nokia Digital Core Technology 4 ( DCT-4 ) 2 11-10-2002 21:36
3330 no tx but good rx [email protected] Nokia Hardware & Hardware Repair 0 05-23-2002 01:49
Page generated in 0.31326 seconds with 9 queries
