Old 09-14-2004, 13:44   #1 (permalink)
Crazy Poster
Member: 79745
Thanks Meter: 27
8210 no signal pls help
i have 8210 i try to flash but not respont pls give me tip. jao
Old 09-14-2004, 14:39   #2 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 47
Why you Flashed the phone ?
sometimes little jumper between antenna and pads does the trick.
Good luck....
regards
Old 09-16-2004, 00:37   #3 (permalink)
Member: 50240
check PA or replace as well as antenna switch....good luck......u need it
Old 09-16-2004, 01:09   #4 (permalink)
Member: 16036
Thanks Meter: 5
hi
@etcelfon
friend since SOFTWAre n msid seems to fine,since u flash and no result
try to CHECK WEATHER RX or TX fault first
then DECIDES weather u need to change coba,26mhz, or pa etc etc
DETERMINE EXACT fault
keep well
bye man
Old 09-16-2004, 01:23   #5 (permalink)
Registered User
flechazo's Avatar
Member: 39250
Thanks Meter: 64
first try to change :
-Pa
-Antena Switch
-Coupleur ( between PA and Antena switch )
Best ReGards Faisal
Old 09-16-2004, 01:27   #6 (permalink)
Member: 16036
Thanks Meter: 5
@flechazo
can u gaurente me THIS specific blind way will SOLVE repair?????
any other STEPS u can tell me?
im interrested
Old 09-16-2004, 01:30   #7 (permalink)
Member: 16036
Thanks Meter: 5
oh
I FORGOT
friend azampk, i will answer on BeHALF of rajumobile
IF U READ CORRECTLY n try to understand
WHAT HE SIMPLY MEANS
FROM ARIEL"ANTENA" take WIRE n join to CONTACT of board where ARIEL suppose to TOUCH "pad"
Old 09-16-2004, 07:18   #8 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 47
@ Mr.mohammed
Exactly. Thanks for explanation on behalf of me.
Sometimes the fault is very minor and it need not require high funda. Nearly 40 % network faults are solved by simple tricks.
Good luck....
regards.
Old 10-06-2004, 09:31   #9 (permalink)
Member: 73455
Thanks Meter: 23
"mohammed"...can u guys put a picture in this thread on how to execute what u mean.
It could help me a lot.
thanks in advance.
regards..
n71 no signal pls. help jhymz Nokia Base Band 5 ( BB-5 ) 2 09-23-2009 02:38
sony ericson z520 no signal pls help.. airtsua_06 Sony Ericsson Hardware Repair 1 03-26-2009 08:07
3510i no signal pls help sq7hqi Nokia Digital Core Technology 4 ( DCT-4 ) 1 01-06-2006 18:21
8210 no signal BorisBonk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 03-26-2001 11:52
Page generated in 0.15386 seconds with 9 queries
