Old 05-21-2003, 22:40   #1 (permalink)
Member: 11926
help before I suicide (nokia problems on my life)
Hello , let me expalin what happens :
I have all hardware necessary to repair phones, or I think I do,
- 100 MHZ osciloscope
- quick 850 hot air station
- flux
- old boards and new components
- I don't have test jig (if anyone has made any tes jig please send me picture to my mail )
- rf led
My problems are :
- 3310 and 8210 wich get's network when it is turned on and after that loses it never getting it
- 3310 and 8210 wich get's network and after a long time when I try to make a call it "beeps" and don't let me make the call.
- 3310 withou any network at all
I need help to repair this phones.. I'm tired of seeing old posts but I get more and more confused. some say PA, other antena switch.. etc...
I NEED A WAY TO TEST PHONE AND REPLACE THE BAD PARTS and not try this and this and this and ...........
I have wintesla and I know how to enable netmonitor, but I don't know wich tests to do.... can someone teach me ?
WILLY is a great guy, and he teachs a lot, I hope you help me if you read this message, .... I 'm getting crazy....
Any help is welcome to my problems.. but please.. always reply with tested experiences and not the "try"....
Thks and sorry for the big post.
KEEP HELPING
Noone0
Old 05-21-2003, 22:47   #2 (permalink)
Member: 11926
I need to know another thing.. I put flux to dessolder all bgas, but I should I remove the solder that stills on the phone board ??? because like on the ccont and cobba places on the phone board there are those littles holes near the bga contacts, and when I take the solder off with the solder iron, they get solder and then, when soldrering again, the bga don't solder well and some parts of the solder goes to that little holes .. how to prevent that ???
thks
sorry for this stupid question..... but that's another problem I have
Noone0
Old 05-21-2003, 23:01   #3 (permalink)
Member: 5992
you don`t have tools for proper RF repair...
- you need JIGs, spectrum analizer and GSM tester...
without proper tools you cant find the damaged component and you will just guessing...
RF repair is like this:
-phone board in JIG connected to wintesla/phoenix and Tester and set to TX or RX and with Spectrum check the signal path to see what is damaged...
-after compomponent is replaced check again and in final calibrate the RX&TX using Tester...
Old 05-22-2003, 01:12   #4 (permalink)
Member: 11926
where can I buy test jigs at the best prices ?
and there anything I can do to repair those phones without these tools ?
Thks
Old 05-22-2003, 04:28   #5 (permalink)
Member: 1060
Thanks Meter: 10
Re: help before I suicide (nokia problems on my life)
- flux
- rf led
My problems are :
Noone0
Noone0,
first, remove casing , then put 68K ( normal mode as normal battery install ) or 22K ohm ( force to local mode as service bettery insert ) , FROM BSI GND, then put power supply to give 4V to VB+ and gnd, then this way you can make phone power up without casing !
2th, try to connect Mbus cable from PC com port to phones, then run wintesla !
go RX :
measure first , all VRX all supply from CCONT !
once wintesla got detail of that phone, then you go to test menu, and set RSSI reading , it must show -110 (+-) dbm
then, you measure that MAD to Hager control R301 (3310) , R205 /R206 ( SENA /SCLK) , if no wave you can see, then MAD is problem !
then go to test Hager to VCO at C558 ( 3310) , or C802 (8210) , then you can see from oscilloscope for around 216hz (CH:60, voltage 3.18V) wave, if you can not see it, try to get one working phone , then make same way to measure it !
if VCO loop is ok, then you go to see R504 ( 3310) , R530 ( 8210) for that RX IP/QP .
then check 32.768 for C220 (3310) , C113 ( 8210 ) to check
that sleep clock is ok or not !
go TX:
meausre all VTX are supply ok !
go wintesla , go to RF control, then set "TX".
then use oscilliscope to measure TX QP R546(8210 ) R541/R548 (3310) , you can see that COBBA send wave to Hager !
then go to tune menu , put your "RF LED" on antenna pad , set TX power level from 19 step up to level 5, then you can see that power supply current went up too !
if LED not light up, then you use LED go to L553 at pin 1 (in) and next pin 7 ( out) to see if your LED light or not , if in pin 1 is OK, then pin 7 is OK too, then antenna switch must got problem , if TXP wave is ok, and TXC level is step up too , then pin 1 has no light up on led, then it most PA problem !
Willy
Old 05-22-2003, 08:32   #6 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
A professional answer as always from Willy !!!
Old 05-22-2003, 12:51   #7 (permalink)
Member: 11926
wow ... hands to work....
anyone has made any test jigs (homemade) who can send me a copy.. like you willy, I read on a forum you made some with the old casings of phones.. can you please send a picture of it to me ?
Thks
[email protected]
Old 05-22-2003, 14:21   #8 (permalink)
Member: 2415
@ mr_x4you:
you're absulutely right
@ willy:
I'll also very much appreciate,
instructions on creating
home made jigs
br,
bone
Old 05-22-2003, 21:11   #9 (permalink)
Member: 1060
Thanks Meter: 10
about DIY or home made test jig, before i use "old" casing ( B-cover), and remove some part for me to measure RF and bese band side !
also you can contact Guciano , he has some photo from he build test jig, i think it is nice to use it
important things, it is how you make thing easy for you to do measure work at phone , i will try to look if i still can fine that "old diy test jig" !
Willy
Old 05-22-2003, 23:43   #10 (permalink)
Member: 11926
thks
how do I get those pictures ?????
noone0
Old 05-23-2003, 01:07   #11 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
@willy: your explanation is the better thing that I have readed a long time ago Thanks a lot, now I have good info to learn more about testing phones (I usually change ic's withouth tests)
about test jigs, I want schemes too... how can I contact with Guciano?
best regards
Old 05-23-2003, 01:09   #12 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
ok, I have sended a mail to guciano
Old 05-23-2003, 13:00   #13 (permalink)
Member: 2415
@ willy:
10x for your support!
if you find the pics i'll very much appreciate if you could send
them to me, or url to down...
@ thecult :
If you receive them can you share them with us by uploading
to somwhere or sending directly to me? to avoid spamming
guciano's mailbox...
10x in advance,
bone
Old 05-26-2003, 20:13   #14 (permalink)
Member: 5992
Sorry guys, I try to attach the pictures you requested but look's like it's not possible for me to atach any file-picture...
So Willy will atach the pictures after will download from my ftp .
L.
Old 05-26-2003, 20:29   #15 (permalink)
DrMobile's Avatar
Member: 5932
Thanks Meter: 1,694
BIG THANKS TO WILLY and Guciano,
KEEP UP GOOD WORK FOR OUR FORUM...
Best Regards,
Wahab
Problem on my Nokia 2700 Classic BERMODA_79 Nokia Hardware & Hardware Repair 1 06-28-2011 14:33
Problem on my Nokia 2700 Classic an0nym0us... Nokia Hardware & Hardware Repair 0 01-04-2010 20:40
help ...UB problem on my computer CellM@n Universalbox 1 11-20-2008 08:20
Major problem on my furious gold box,please help.. carlluvjo FuriousGold 1 09-22-2007 06:39
Page generated in 0.30285 seconds with 10 queries
