10-27-2003, 22:11 | #1 (permalink) |
Junior Member Join Date: Nov 2002
Member: 18286 Status: Offline Thanks Meter: 0 | 8210 Turns ON when battery inserted & OFF on key press Ive got this 8210 sitting here in front of me which seems to work Ok. It will ring, but as soon as you press any key phone then turns its self off, also when You put the battery in the phone it automaticly turns on will start normaly, untill you press a key where it again will turn it self off. I tried to flash the phone, but rollis wont allow me as it tells me to turn the phone off, but as soon as i put the battery in... you gussed it, it turns it self on.... MTIA |
10-27-2003, 23:20 | #3 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Banana Republic of Germany Age: 55
Member: 7769 Status: Offline Thanks Meter: 0 | sounds like a little water damage, check the on/off switch and the User Interface chip - i it looks a little bit green - > water about that flashing problem: its no problem, it depends on timing - but in your case - its no software error - its a hardware error |
10-28-2003, 22:28 | #4 (permalink) |
Member: 18286 Status: Offline Thanks Meter: 0 | K thanks Ive cleaned and reheated the phone and all seems ok though the switch can be a bit flakey, some times needing a good press to get it working, so if it continues to be a bit hard to turn on or the old problem returns I shall replace the switch. |
6680 auto on when battery insert | gants | Nokia Hardware & Hardware Repair | 9 | 12-26-2009 06:03 |
6680 auto on when battery inserted | tonitze | Nokia Hardware & Hardware Repair | 3 | 03-23-2009 08:23 |
D600 problem-phone doesnt turn on, when battery inserted vibrates permanently | robbie | Samsung Hardware Repair | 3 | 02-02-2008 20:41 |
6210 on when battery inserted | emso | Nokia Hardware & Hardware Repair | 3 | 09-13-2004 15:27 |
8310 starts on when battery inserted? | gsm2 | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 07-05-2004 17:57 |
