11-05-2002, 02:00 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | 8210 with very weak network ive got an 8210 with a very weak RX signal. In netmonitor is always around the -109 or totally gone. In Wintesal RSSI is around -120. This problem appears on both 900 / 1800 mhz. What could it be? I want to make sure what it is before I start blidnly replacing parts. TX is OK |
11-05-2002, 06:42 | #2 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 8210 with very weak network Scaramouche , Check at AFC from Cobba , or AFC not under control ! it is TCXO problem or COBBA ! Willy Quote:
11-07-2002, 01:59 | #4 (permalink) |
Member: 11937 Status: Offline Thanks Meter: 1 | maaaan, have I had a bad day. I took the cobba off, reballed it, nad went to put it on. I must have used too much heat or liquid flux, because suddenly there was a loud pop & every capacitor in that large bank near cobba jumped right off the board. . resoldered all 12 of them back, but now iam getting cobba parallel failure. Iam going to rework cobba again or change it. BUGGER |
i have N78 network very weak any solution | romio_16 | Nokia Hardware & Hardware Repair | 4 | 07-26-2013 19:17 |
N95 with very weak signal | rodrigocaputira | Nokia Hardware & Hardware Repair | 1 | 04-22-2010 08:15 |
n2650 network very weak | sajidmirza | Nokia Hardware & Hardware Repair | 3 | 07-11-2007 09:35 |
8210 with batery discharge very quickly, any solution ? | Kilowat | Nokia Hardware & Hardware Repair | 4 | 03-22-2002 14:49 |
Motorola L series network very weak? | bobby8850 | Motorola Hardware Repair | 1 | 12-08-2001 11:31 |
