04-28-2005, 05:55 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 44
Member: 92067 Status: Offline Thanks Meter: 10 | 8250 flash erasing error(battery voltage is too low) have nokia 8250 first time is no network and after try repairing phone i need to reflashing phone with nokia flasher by rolis 4.78 when need pressing power on phone, i pressing power on button but rolis said flash erasing error(battery voltage is too low) i ceck battery voltage using multi meter and with others phone battery full. what the problem is........... regards |
04-28-2005, 06:00 | #2 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: I N D I A Age: 43
Member: 100579 Status: Offline Sonork: 100.1578318 Thanks Meter: 106 | Quote:
this might solve ur problem. regrds. | |
04-28-2005, 06:08 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
use power supply 3.6V as your battery and get nice flashing.... | |
04-28-2005, 16:30 | #4 (permalink) |
Member: 92067 Status: Offline Thanks Meter: 10 | I try rehoting CPU and reflashing work normal but still when i pressing power button battery indicator show low bat or only one bar in battery indikator but i try use the battery to another phone battery indikator show full bar. i need to use eeprom tools to update faid,unlock,change imei but phone not connected. |
04-28-2005, 17:11 | #6 (permalink) |
Insane Poster Join Date: Aug 2004 Location: Jakarta-Indonesia Age: 46
Member: 77719 Status: Offline Thanks Meter: 0 | By Rolis 478b "Flashing Erorr batteray Voltage Is Too Low CheckVPP???" In Indonesia: Harap Periksa Teganggan Strum Tembak KE IC-Flash (STEP UP) Voltase <---Normal Atau Tidak??? Ibarat Kata Anda Menembak Dengan Peluru Hampa... Maka Flashing Akan gagal Atau Di Flashing Mulus Tapi Tidak Hidup.... Pas Di Read Ulang File Tidak Mengisi Di IC-Flash....Bukan Karena IC-Flash Rusak Atau CPU/Mad Tidak Bekerja.... In English: You Must Check Voltage Control To IC-Flash Cause While Flashing...There is A Voltage Control To SHOOTING The File From Your PC To IC-Flash Ussualy About 5v to Write.... Check The Black IC With 3 Foot Around Or near C-Cont... Change IT.... wassalam wiradinataR |
05-02-2005, 15:08 | #7 (permalink) |
Member: 92067 Status: Offline Thanks Meter: 10 | I already doing all................ in indonesia : semua sudah saya lakukan hehehehe pertama mmg tidak bisa di flash dan ada error pesan flash erasing error(battery voltage is too low) dan setelah saya panasi MAD dan saya flash lagi berjalan normal dan sukses tapi............. itu dia battry itu klo dipasang ke hp lain full tapi ke hp itu cuma satu titik dan selalu low batt. in english : after rehoting MAD and i try reflashing again and all done but the battery if using to others phone battery indicator showing full but if im using to that phone showing low batt and ussualy after reflashing we need use eeprom tools to make change imei,update faid,and unlock but when using eeprom tools i have phone not connected. regards, nb. wiradinataR ur members in here to |
06-01-2005, 17:09 | #9 (permalink) | |
Freak Poster Join Date: Jul 2003
Member: 34310 Status: Offline Thanks Meter: 23 | @ gama_cell99 Quote:
This morning I have just repaired 1 8250 as same ur problem. Rework Flash or change new once!!!. 100% will be OK. B.R Vinh Hai | |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-23-2005 06:01 |
3310 flash erasing error (battery voltage is too low) | pana_java | Nokia Hardware & Hardware Repair | 2 | 04-04-2005 14:46 |
C330 flash erasing stopped phone is dead pls help me!!! | !!!TaaTTalTi!!! | Motorola P2k | 5 | 11-26-2003 10:34 |
Flash erase check (battery voltage too low) | scanner | Nokia Hardware & Hardware Repair | 4 | 11-11-2002 17:29 |
Flash erase check (battery voltage too low) | scanner | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-08-2002 17:04 |
