Old 09-03-2005, 12:39   #1 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
7610 Flash Ic Compatable...,
Need To Know What Is The 7610 Flash Ic Compatable...?
Dows 6610i Or Flash Ic Work On It ...?
Or Which Model ...?
Pls Help
Old 09-04-2005, 06:35   #2 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
There 2 flash chips inside - so what one you need to change? ... and 6610i is incompatible for sure - first - it's a small size, second - it's a combo flash/RAM device, but 7610 use separated Flash and RAM IC-s.
Old 09-04-2005, 12:12   #3 (permalink)
Registered User
Member: 39208
Thanks Meter: 152
The Flash Ic Is D460...
Pls Help
Need The Compatable Flash Ic
Byte
help in 7610 flash ic yasser_elawad Nokia Hardware & Hardware Repair 4 06-10-2007 21:45
7610 flash ic (f10) not detected psyrooze WD2 & APE (Symbian Phones) 1 08-25-2006 19:21
7610 flash ic GSMJordan Nokia Hardware & Hardware Repair 6 10-05-2005 22:29
7610 flash ic and uem solder type genocite Nokia Hardware & Hardware Repair 6 11-22-2004 19:58
Nokia 6100 flash IC compatibles ...?? Medz Nokia Hardware & Hardware Repair 0 03-27-2004 18:46
Page generated in 0.13054 seconds with 10 queries
