Old 02-18-2003, 00:47   #1 (permalink)
Member: 2466
Thanks Meter: 10
Angry N3310, vibra & LEDs are on when connect battery, but phone is dead
I have Nokia 3310 wich is dead, but when I connect battery, vibra and all LEDs are on until I press power button. Then vibra stops, and LEDs turns off, but phone don't power on
When I disconnect, and connect battery, vibra, and leds are on, and always the same...
I changed N400, and rehot pcb, but nothing
I try to flash it, but phone doesn't respond to flasher...
Does anybady know where can be a problem?
Old 02-18-2003, 13:35   #2 (permalink)
Administrator
Member: 3188
Thanks Meter: 2,394
From Hardware Repair Moved to nokia H/W
Old 02-18-2003, 15:20   #3 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
try ccont..
Old 02-18-2003, 15:37   #4 (permalink)
Member: 4239
Thanks Meter: 2
change "nmp70433" !
Old 02-18-2003, 17:19   #5 (permalink)
Member: 2466
Thanks Meter: 10
Originally posted by aWar
change "nmp70433" !
nmp70433 is N400 and I changed it before
Old 02-19-2003, 16:02   #6 (permalink)
amir-cairo's Avatar
Member: 11466
reballing yr ccont man yr broplm on it just
wish u have a supporte by this information
Old 02-19-2003, 19:13   #7 (permalink)
Member: 7062
Thanks Meter: 126
I THINK YOU HAVE A WATER DAMAGED PHONE...
CUZ IT SEEM THAT U HAVE SHORT AROUND
Old 02-20-2003, 01:19   #8 (permalink)
Member: 2466
Thanks Meter: 10
I changed ccont, but nothing
This phone is not water damage, but I think that this phone droped in some oil or something like oil.
Before rehoting phone was dead, and sometimes it succes to power on, but only for max 30 seconds, and then powers off by itself.
After rehoting all pcb (except cpu, ram and flash) vibra and lights are always on until I press power on button.
Old 02-20-2003, 02:32   #9 (permalink)
amir-cairo's Avatar
Member: 11466
did u check a system keybad ic?
did u check a cobba?
u can say that yr phone is totaly dead
so
1- check if u have a short on system keybad IC
2- remove cobba and power on if it damaged u well see contact service in yr screen
3- check ccont (reballing or chang)
4- check power cristal
5- check a transistor beside power cristal
6-check flash IC and ram
7-yr mad
thats all
write flash checksum OK....But phone is dead amol_sm Universalbox 7 06-12-2009 22:22
unlocked sonyz200, but phone is dead? mustangmoto Sony Ericsson 3 09-13-2004 00:01
N3310, vibra & LEDs are on when connect battery, but phone is dead MaRiN Nokia Hardware & Hardware Repair 2 02-19-2003 20:45
Page generated in 0.15522 seconds with 9 queries
