Old 03-07-2004, 10:59   #1 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
8310 contact service
I cant flash it...
when i try to read the reason of the contact service with the phonix.. the phonix did not detect the phone on fbus(either tx or rx not wroking).. but with the mbus the phonix read it.. and gives the following error when i select the "Self test"
Error while running all possible Selt Tests.
HRESULT 0x80041009 (-2147217399)
can some one guide me what the above error means ?
br
Old 03-07-2004, 14:32   #2 (permalink)
Member: 5358
Thanks Meter: 211
maybe your audio IC is damage or your Power ic.check it.
Old 03-08-2004, 15:16   #3 (permalink)
Springer's Avatar
Member: 15909
8310 Audio ic + power ic =~ UEM ic.
Old 03-09-2004, 02:41   #4 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Sometimes it is not the UEM, but the UPP which is faulty. It could also be the HAGAR, if an old part number was used (ie, 70467) -- self test will report RF IC failure.
Old 03-10-2004, 23:30   #5 (permalink)
Own
Member: 5569
Thanks Meter: 10
if you used sw pheonix and you cant use Fbus please check UEM 10000000000000000000%work [ try to rehot]
and your phone have pb. with contact service add your pb. about Fbus
1000% your UEM is BAD
regards
Own
Old 03-10-2004, 23:36   #6 (permalink)
Own
Member: 5569
Thanks Meter: 10
............ if you used sw pheonix and you cant use Fbus please check UEM 10000000000000000000%work [ try to rehot]
because it....please you see schematic diagram about UEM at leg N5,P5
- N5 = FbusTX0
- P5 = FbusRX0
regards
Own
Old 03-11-2004, 07:17   #7 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
yes.. its the uem fault...infact when i have removed the uem.. few print under the uem are out...
br.
8310-contact service--? F C Nokia Digital Core Technology 4 ( DCT-4 ) 0 02-16-2002 10:30
8310 contact service s4sajii Nokia Digital Core Technology 4 ( DCT-4 ) 2 02-08-2002 14:41
8310 contact service / sim card restricted ? ACE_UK Nokia Digital Core Technology 4 ( DCT-4 ) 0 02-04-2002 13:20
8310 contact service??? pavlin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 01-20-2002 10:01
8310 Contact Service kash2k Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 12-05-2001 02:10
Page generated in 0.15406 seconds with 9 queries
