Old 04-23-2004, 21:15   #1 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
8310 dead Toooo........!!!!!
Dear All I try reflashing 8310 dead phone with griffin and other DCT-4 flasher program but never success and cant LOCAL MODE what the problem is????
Help......
regards,
uwenk98
Old 04-24-2004, 13:06   #2 (permalink)
Member: 44658
what error, it come up with when you flash?
Old 04-24-2004, 18:08   #3 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
My Griffin activated box said : "Flashing FAILED Make sure phone is connected and powered! ErrCodes: [01:8888]"
Old 07-27-2004, 07:50   #4 (permalink)
DEVILvn's Avatar
Member: 37678
i tested on n6510 with same problem. u try to setup new again windown & griffin. maybe work well.
Old 08-31-2004, 23:58   #5 (permalink)
Member: 29365
where to download old version of Griffin such as Griffin V2.02 to fix my dead 8310 . Please help i have tried Griffin site, but there is only .pdf files .
Old 09-01-2004, 01:25   #6 (permalink)
MaFiaaa's Avatar
Member: 57930
Thanks Meter: 24
try onther box like twister or brodigy if the same change flash IC
good luck
Old 09-05-2004, 23:17   #7 (permalink)
DEVILvn's Avatar
Member: 37678
contact me. i'll send u.
WBR
Old 09-07-2004, 16:44   #8 (permalink)
Member: 10528
Thanks Meter: 4
Help......
regards,
uwenk98
what do you mean uwenk98 your box have damage or your phone can not come up
if your box is work normaly and you connect the phone and cant flash it is 100%
phone problem .... try to check your phone cpu or uem maby have some wrong things
Old 09-10-2004, 01:30   #9 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 56
Help......
regards,
uwenk98
SHOULD ALL "NO POWER" cases be software related??
explane more (was your phone working be4 flashing) ?
Old 09-10-2004, 17:59   #10 (permalink)
MaFiaaa's Avatar
Member: 57930
Thanks Meter: 24
chech FIA files 1st if u can`t get acces with griffin chech hardwar
if voltage on seitch > 3.2 then change flash IC if < 3.2 then change UEM or check prossisor
GOOD LUCK
8310 dead mix00 Nokia Hardware & Hardware Repair 6 09-27-2002 04:46
Nokia 8310 dead after somany SMS mulu Nokia Digital Core Technology 4 ( DCT-4 ) 3 08-10-2002 03:59
8310 Dead gsnbhagawan Nokia Hardware & Hardware Repair 1 06-30-2002 13:48
8310 dead ..... i m shocked. PTR999 Nokia Digital Core Technology 4 ( DCT-4 ) 2 12-14-2001 11:23
8310 Dead j2000 Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-14-2001 07:53
Page generated in 0.20817 seconds with 9 queries
