Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2002 Location: Asia
Member: 19208 Status: Offline Thanks: 0
| 8310 flash OK, once turn off, can't turn-on again! My firend have a 8310, it was working good. After flashing with Cheap DCT4 flasher: 1) Flashing OK 2) Will turn on and work like normal 3) If Turn-off 4) Never turn-on again 5) Flashing OK 6) Will turn on and work like normal 7) If Turn-off 8) Never turn-on again 9) ............... 10) ............. I tried to flash it with Griffin. Same result! Same case here: 8310,8910 dead Oh ..... one more interesting thing. If I don't do any "master reset" (Restore Factory Default), the phone will turn-on like normal! What seem to be the problem? Please help !! |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2003 Location: Pearl of the Orient
Member: 42539 Status: Offline Thanks: 47
| flash it again with griffin, then when it starts erasing for a few seconds, disconnect fon from griffin. now its dead. flash it again, mcu = mcu, ppm = mcu, flash it again normally using highest version you have w set to factory default & unlock. long wait but its works for me. try it & see what will happen. |
| | #5 (permalink) |
| @kcgckc2002 I tried exactly what you said, no luck! Same problem! If I don't master reset (restore factory default), the phone will work like normal, but once it is master reset, it won't turn-on again! |
| | #7 (permalink) |
| @dannyogolo, Thanks for the reply! I did apply some hot-air to the flash IC and also c-cont, but nothing improved! It seem more like a software problem rather than hardware. Because if you don't give it a master reset, it works just like normal! |
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2003 Location: somehere Age: 29
Member: 31028 Status: Offline Thanks: 4
| it could flash ic too, don't forget that griffin gives power to phone too. it might be there the problem, without griffin the power does not receive enough power something like that, check all possibility it is very strange, u can try to write rpl file too... |
| | #11 (permalink) | |
| Quote:
Yes, I did rehot the PCB, flash IC and etc. Same problem! I think it is rather software problem! | |
| | #12 (permalink) | |
| Quote:
| | #13 (permalink) | |
| Quote:
BB selftests = 100% pass when the phone is normal! BB selftests will not work if the phone is refused to turn-on! | |
| | #15 (permalink) | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| j220i relock after turn off and turn on | thienchi | Sony Ericsson | 6 | 09-18-2008 12:29 |
| V60i suddenly turns off and turns on after 2-3 seconds | buletz | P2k Series | 0 | 04-17-2006 13:34 |
| My QD turns off and turns on only after u plug in charger. WTF? | Shved | WD2 & APE (Symbian Phones) | 0 | 10-16-2005 02:21 |
| 8310 flash ok,not power on!!! | kostenlose | Nokia Hardware & Hardware-Repair Area | 10 | 07-25-2004 04:58 |
| SE T100 After turn Off can't power on for 30 min. | kovacn2 | Sony Ericsson | 4 | 12-12-2003 12:05 |
