01-29-2004, 13:46 | #1 (permalink) |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | 8310 no network at all i have reball the uem... stil same... than.. changed the new uem.. upload the rpl file and set factory defaults... but still same.. any one have any idea? or suggestion br |
01-29-2004, 16:42 | #4 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Quote:
Willy | |
01-30-2004, 15:47 | #7 (permalink) | |
Member: 6919 Status: Offline Thanks Meter: 12 | Quote:
what are the good values of rssi and TX power level for the 8310.. my pkd1 dongle is at home.. i will test it tomorrow and post the results.. br | |
01-30-2004, 23:46 | #8 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | @platt u can put hagar from 8310 on all new models that have hagar IC, and it will work, as dual band only ... antenna switch ... try with 0508a or 0508b depending on PF ... it will work too plattjett, seems like you know only numbers and in reality ... very little, right ? no offense, but some time try some things dont just write ... impossible bla bla bla b.r. Alexandar. |
01-31-2004, 15:00 | #9 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Greece Age: 47
Member: 26279 Status: Offline Thanks Meter: 274 | @brka really.......????? please post here measurements with original antswitch and 0508a and 0508b. maybe some times phone shutdown when transmiting because of 0508...????? |
01-31-2004, 20:26 | #11 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,777 | @platijett ... hehe ... as I said ... u are too much connected with numbers ... it can work without switcher too ... just with wire patch ... @legija yes it is switch for old phones ... which can ALSO BE USED with 8310 or 6310 etc. today i put one switch from 6210 to 6310 ... also working all ok because i left out of original switches ... first aid guys ... when u left out of original parts ... some other can be used too b.r. ALexandar. |
01-31-2004, 22:14 | #12 (permalink) |
Member: 26279 Status: Offline Thanks Meter: 274 | @legila yes 0508 can work on 8210,6210 etc. @brka please post measurements. manufactor is not stupid. ANTSWITCH have reason to be there and the reason is: antenna can't be conected same time with transmiter and receiver and diplexer do this job(x/T to transmiter and x/T to receiver).some pictures on internet is showing wiring between pins on diplexer is but after this wiring you will not have dual band signal and after few days you will have big damaged RF part. @willy with your experience what do you think about this? |
09-22-2004, 23:36 | #14 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | i have problem with no network on 6510. Ant sw is ok Hagar changed . FDK is OK UEM reflowed . still no network on manual search /after few seconds/ . Any other idea? Phone was dropped. Pali |
03-01-2005, 23:02 | #15 (permalink) |
Freak Poster Join Date: Nov 2002 Location: neverland Age: 45
Member: 18165 Status: Offline Thanks Meter: 12 | 6510 network problem when i turn the phone on the nework is thre for about 3-5 seconds andthenits lost if you try manual search the phone finds it but can not register to it evenafter 1 minute and also the phone shuts itself once in a while any help would be apreciated |
T600 no network at all | genocite | Sony Ericsson Hardware Repair | 9 | 05-21-2004 15:05 |
6310 NO network at all | msas | Nokia Hardware & Hardware Repair | 2 | 08-11-2003 16:40 |
8310 no network at all | delta1 | Nokia Hardware & Hardware Repair | 0 | 06-27-2003 16:22 |
1018 no network at all? | NBG | Hardware Repair by brands | 2 | 11-16-2002 02:42 |
5110-NO NETWORK AT ALL!?????? | cosmo | Nokia Hardware & Hardware Repair | 8 | 10-30-2001 12:17 |
