Old 06-14-2004, 14:59   #1 (permalink)
Member: 63385
Thanks Meter: 3
Question 8310 Radio not working...
Wat to do with 8310 Radio not working?.. I have replaced d radio IC but stil having d problem... Wat to do?...
merulez29
Old 06-17-2004, 01:32   #2 (permalink)
Member: 69056
just try replacing the radio ic... does it says no channels found or connect headset?
if it doesnt work after replacing an ic try the filters.... the 2 white square components at the side of the radio ic...
regards~~
Old 06-17-2004, 03:30   #3 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 134
flash with newest version v6.20, if still change radio ic (must original, cheap ic is bad)
Old 06-17-2004, 07:46   #4 (permalink)
Member: 63385
Thanks Meter: 3
Question
yeah thanks!... Actually the problem is when i open the radio menu it doesnt open it goes back to main menu. I've already replaced it with new original Radio IC but problem s still d same.
merulez29
Old 06-19-2004, 15:40   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 465
merulez29
hahahahahahaha
Man
Its Software Prob !!!
Flash with latest Firmware & it will be Ok
Old 06-19-2004, 16:30   #6 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 236
change upp 100% working
Old 07-28-2004, 17:31   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,060
update new sw 6.20 nor worked. still hang when open radio.
upload good pm still hang when open radio.
change upp?? wow, its better to buy a pocket transistor radio......
no solved yet, so i sold this phone
Old 08-04-2004, 17:51   #8 (permalink)
Member: 16430
Thanks Meter: 2
merulez29
Solution is replace Philip radio IC.
Old 10-21-2004, 18:11   #9 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 356
hi,
i got this problem too. when i try to open radio with headset it goes stanby screen(main screen). without headset display message "connect headset".
software version is 6.20 . before problem phone drop once, operate sound recorder with full recording. i need ideas
thanks in advance.
Old 01-06-2005, 09:47   #10 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Originally Posted by gsmbac
hi,
thanks in advance.
Have u solve your radio problem yet? i tried everything accept changing the UPP and the radio IC. my problem still the same.
Old 01-08-2005, 08:27   #11 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
i have change the UPP (CPU) but still the same problem.
Old 01-10-2005, 08:32   #12 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 356
hi' my problem solve after flashing.
Old 01-10-2005, 18:26   #13 (permalink)
kham's Avatar
Member: 3026
Sonork: 100.1602750
Thanks Meter: 90
i repaired a lot 8310 without flashing
only by changing radio ic
check white SMD (perhaps condensator)
Old 01-11-2005, 00:13   #14 (permalink)
Member: 38922
Thanks Meter: 35
Always first Update then check and change. Work with SM!
GreetZ
Old 01-11-2005, 18:50   #15 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,060
SURE: Update ---> Check ----> replacemen.
No result ____________ BOARD SWAP!!
@cyberoptik THX for the picture,, next time i need any picture, i'll contact you directly... hee..he..he.. Do you mind?
6101 radio not work erayturkoglu Nokia Hardware & Hardware Repair 3 05-01-2007 23:42
8310 radio not working robbyslam Nokia Digital Core Technology 4 ( DCT-4 ) 4 05-05-2005 17:14
8310 radio not functioning fzlmn Nokia Digital Core Technology 4 ( DCT-4 ) 2 01-31-2005 03:28
8310 mic not working... drej2004 Nokia Hardware & Hardware Repair 3 05-27-2004 10:23
8310 vib not working Raf_06 Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-20-2004 14:08
Page generated in 0.42013 seconds with 8 queries
