05-15-2004, 18:42 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Age: 46
Member: 10483 Status: Offline Thanks Meter: 23 | 8310 vibrate but no ring ( no ringer , no ringtone) and not software problem I have a 8310 with strange problem. I have seen a lot of post with that, but me it s not software problem cause I upgrade it with last version (6.20) and my phone vibrate. If any idea your welcome |
05-17-2004, 23:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | from here it is hard to help since we dont have the phone at hand. Try to get anothe good one and compare the main contacts and follow back using a multimeter. Can take you sometime to arrive at the problem but that is troubleshooting However i presume that you have either a broken track or else something near or problem with UEM itself since this one contains the beloved Cobba now. g luck mate al |
05-18-2004, 10:12 | #3 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Wien,Austria
Member: 45985 Status: Offline Thanks Meter: 96 | And you could test buzzer first,just take 5V battery and connect it on + and - on buzzer.So if you hear any sound,itīs ok and you have to check other components and tracks between them(you can do it easily if you have service manuals). |
05-18-2004, 20:41 | #5 (permalink) | |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Quote:
A 5 Volts onboard !!! , it is very risky man . the components of the mobile phones are CMOS construction , the unit volt level here is 1,8 volt appliying a 5volts on board is very risky and it may dammage any thing on it specialy the UEM ( the power manegment device ). By the use of a multimeter on a resistance meter U can mesure the resistance of the buzzer ( around 16 Ohm ) , as U see so simple BestLuck Br | |
05-18-2004, 21:37 | #6 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | @ gsmnice 1. First try to follow the service manual mate. Preferabbly do use the proper tools else it will be harder. 2. If not possible try comapre to another good board. NEVER EVER try heating the board or applying voltages at random unless you are 100% sure what you are doing. Phones are delicate and a careless move can mean a dead set of chips and not worthwhile to fix. g luck al |
05-19-2004, 16:25 | #7 (permalink) |
Member: 45985 Status: Offline Thanks Meter: 96 | Yeah,5V can be heavy for phone but till now I had no problems with that. Iīm doing it only when i suspect on water damage or if someone has already repaired phone and havenīt cleaned the board properlly(buzzer can be glued with rests of flux or oxidated) and you canīt see that and the resistance can still be correct,isnīt it? |
1600 no ring tone & no incoming voice lout spk ok | babubehera | Nokia Hardware & Hardware Repair | 11 | 04-11-2013 07:04 |
1600 no ring tone & no incoming voice | abhishekh53 | Nokia Hardware & Hardware Repair | 26 | 08-15-2011 16:25 |
6510 no vibrate but can ring | VEX-CELL | Nokia Hardware & Hardware Repair | 0 | 01-19-2008 05:00 |
GD95 with Blank IC- Not Software Problem | tanim_1976 | Panasonic | 0 | 05-12-2003 18:25 |
T191 dead. Not software problem. | NSerN | Motorola Hardware Repair | 2 | 04-06-2003 15:45 |
