09-03-2004, 19:25 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | 1-bad solder of uem 2-bad connection in boards pin 3-bad uem ic return 4-you might heat the upp or flash ic by wrong i recommend you to use 100%uem and try even its little expincive br |
09-24-2004, 19:16 | #4 (permalink) |
Freak Poster Join Date: May 2004 Location: south africa Age: 45
Member: 65032 Status: Offline Thanks Meter: 5 | 8310 when replace uem now... remove uem and check if all pads is still there. if all is still there, remove solder from board and replace with new uem.worked for me! cheers!! |
7610 Dead-flashing Ok-in It Local Mode Failed-replaced Uem-still Dead | zonetrichur | Nokia Hardware & Hardware Repair | 26 | 03-27-2010 08:06 |
What Should I Do After Replace UEM | MPK | Universalbox | 1 | 01-28-2009 17:16 |
Nokia 3120 Killed after replacing UEM | ansari_nazeel | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-04-2006 19:14 |
Replacing UEM chip URGENT | hustler | Nokia Hardware & Hardware Repair | 0 | 09-03-2005 13:04 |
AGAIN 1100 replace UEM | saso | Nokia Hardware & Hardware Repair | 3 | 08-17-2005 21:50 |
