Old 07-13-2004, 14:56   #1 (permalink)
Member: 69785
Thanks Meter: 3
8850 no network
Hi,
I've get a faulty 8850. It has Network (D and E) only shortly after switching on. Not make a telephone call possibly. Himself look for it at a manual Network search stupid and stupid. I guess the PA. I have opened it once and pressed with the finger of the PA. After that it no Network, not after switching on briefly now.
What could exactly be faulty?
Sorry, for my bad English;-)
Old 07-13-2004, 16:32   #2 (permalink)
b0ba's Avatar
Member: 6772
Thanks Meter: 17
Just change PA.
Possibly HAGAR. Enable netmonitor and tell us test 1 readings.
Old 07-13-2004, 16:48   #3 (permalink)
Member: 72579
Could be HAGAR,if signal going up 1,2,3,4 and when You calling going down 4,3,2,1 but also could be PA.Try to replace PA first
Old 07-13-2004, 16:51   #4 (permalink)
Member: 69785
Thanks Meter: 3
Test1 ( changes every second ):
71 -73 xxx
0 0 x xxxx
34 34
CCCH
Old 07-13-2004, 17:33   #5 (permalink)
Member: 4274
Thanks Meter: 18
Thams,
try to dial 112 then observe the xxx (TxPwr). or try to measure VCC=2.8Vdc for VCO and Vchp=4.8Vdc. or if you got RF LED put it close to antenna then using wintesla set phone in Tx Burst Mode then if RF LED light up then most likely you got a working PA and antenna switch.
Nokia 8850 No Network Found SVH Nokia Hardware & Hardware Repair 3 05-25-2003 22:35
8850 no network and cant flash YeTi Nokia Hardware & Hardware Repair 1 05-10-2003 21:16
8850 No Network Please Help!!!!!! WesleyCHC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 12-30-2002 04:08
8850 no network sometimes??? YeTi Nokia Hardware & Hardware Repair 2 12-19-2001 13:24
8850 No network 43e08 Nokia Hardware & Hardware Repair 5 11-11-2001 19:07
Page generated in 0.21777 seconds with 10 queries
