11-29-2000, 15:39 | #1 (permalink) |
Major Poster Join Date: Oct 1999 Age: 54
Member: 602 Status: Offline Thanks Meter: 0 | got "Contact service" not with unlocking... i'm not unlock phone, not changing imei... i just got "Contact serv" on displei WinTesla give me failed message on PPM Checksum is where only way to get phone work is flash it? may be i might turn off PPM checksum check(like PPM Validity test on start-up)? any help? thanks |
11-29-2000, 22:30 | #2 (permalink) |
Guest
Posts: n/a
Member: | Hi, As far as I know PPM file is responsible for the data contained in the eeprom, Cobba and languages in the Flash. So to have that problem I think should be Cobba or eeprom faulty, or just communication between the Cobba and MAD2 chip. If you phone is 5110 you can still change the eeprom and Cobba from another phone - cheapest solution. If you can Flash - try it. You can turn off the WinTesla check, but you can't stop the MAD2 to check the phone before executing the code. Regards [This message has been edited by Bph&co (edited 29 November 2000).] |
12-08-2000, 13:31 | #3 (permalink) | |
Freak Poster Join Date: Jun 2000
Member: 1641 Status: Offline Thanks Meter: 54 | hi, power on, phone show insert card, after LCD black and show contact service. this is PPM FLASH file destory some bytes. you just need change Flash or program Flash.you must change with some version Flash. can't downgrand or upgrand to other version.use wintesla or other soft check the version. test with 5110,5146,3210 also 3310. b.r. LIKI999 Quote:
12-09-2000, 08:27 | #5 (permalink) |
Freak Poster Join Date: Nov 1999
Member: 719 Status: Offline Thanks Meter: 1 | hi, i got this "Contact service" not bec. of unlocking, when i check it using wintesla (test), it says "COBBA serial..... failed" and others run OK, any ideas for this problem? i also checked COBB chip and resoldered it (including flash and eeprom but not MAD) but no luck regards, koloksky [This message has been edited by koloksky (edited 09 December 2000).] |
12-09-2000, 17:52 | #6 (permalink) | |
Member: 1641 Status: Offline Thanks Meter: 54 | hi, try with solution by KoToT or change one new eeprom. good luck. b.r. LIKI999 Quote:
nokia 6500s got contact service during the unlock time | rajendrakumar | Universalbox | 11 | 04-05-2009 13:34 |
