8890 will not turn on unless first connected to a charger (actively charging) Hey guys, I have a problem with my 8890. It will not turn on, unless I plug the charger in. Once I hear the little beep (that Nokias make when they begin to charge) I can push the on/off button and the phone will turn on. I can then disconnect the charger and use the phone without problems. However, if the battery dies or I accidentally turn off the phone, I am not able to turn it back on without connecting a charger to it again. I know the battery is not the problem because I have tried several others & each time the same happens. I first took the phone to a Nokia Service Center and they said: "sorry, the problem is internal and we do not repair those kind of things." So then I took the phone to a GSM service shop they said: -the on/off switch is good -ccont is working -the battery connector is fine -the system charging block is fine Basically he said sorry, I won't charge you because I do not know what the problem is. Anyone have a similar problem like this? Any solutions/suggestion will be much appreciated. Thank you in advance, 8890guy |
^ Can anyone help me out here? I really don't know what the problem could be. I will greatly appreciate any advice offered. Thanks everyone, 8890guy |
