Old 04-20-2004, 23:22   #1 (permalink)
Member: 6396
Thanks Meter: 18
8910 always on "Headset" profile, please help!
I got a strange 8910 from a customer that was really damaged, somehow he managed to damage the simcard contacts so i fixed them, but when I entered the pincode it starts up normaly but goes directly to headset profile, i checked the flexcable and 3 of the wires was broken, so I changed the flexcable but it didn't help :-(
I got the flexcable without any components on, and im not 100% sure that all the capasitors/resistors is sitting in the same direction as before, but does this matter?
I've also reflow/reheated all the chips on the board but nothing helped, any ideas?
what can cause the phone to think that a headset is connected all the time?
And is the anything i can do to disabled the headset somehow? bridge some point or remove some components?
- the customer says he don't need to have the headset possiblity cause he uses bluetooth headsets.
Any help would be appreciated! Thanks!
//SubTen
Old 04-21-2004, 08:59   #2 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 66
hi
i got one 8910 headest problem and i solved this. my 8910 problem is damage flexcable.
Old 04-21-2004, 10:34   #3 (permalink)
evilspell's Avatar
Member: 4160
Hi,
Till the Audio (part) is on the UEM,so i think that you must change it (Uem) and it must work.
br
Old 04-24-2004, 18:43   #4 (permalink)
Member: 6396
Thanks Meter: 18
Im pretty sure that it's not the UEM chip, does anyone know how the phone detects the headset on a 8910? wich pins gets shorted on the flexcable when the headset is plugged in?
Old 04-24-2004, 20:07   #5 (permalink)
Member: 32182
Thanks Meter: 2
i have same prbl. with 6100 droped in water ! i think some line broken from UEM to mic.
Old 04-24-2004, 21:14   #6 (permalink)
Member: 6396
Thanks Meter: 18
I still think that my problem is related to the flexcable, but i need some info on the lines on it, cause maybe some of them is shoted or broken :-( but nothing to see directly on the flex...
Old 04-24-2004, 21:38   #7 (permalink)
Member: 39601
Thanks Meter: 13
@subten...
The UEM detectes the presence of the headset plug by a small leaf Sw inside the socket when the jack plugs-In , that Sw is allways ON .
The pathway of that detector comes from the UEM to be allways toutching one of the Xearphone's tracks , the components on the socket area are not acting in this operation . All are on the main board , So U need to check the pathway all and the Sw inside the socket , then on board check also R155 ,and R165 (dual 22ohm).
GoodLuck
Old 04-29-2004, 05:39   #8 (permalink)
Member: 24929
Thanks Meter: 7
Originally Posted by Medz
@subten...
GoodLuck
no no no its the flatcable, try an other one or buy a compled cable, soldering a flatcable is very difficult 100% for sure if you use an other flatcable the problem is gone
Old 04-29-2004, 13:59   #9 (permalink)
blue1's Avatar
Member: 60613
must be flexcable.... my opinion
Old 04-29-2004, 15:09   #10 (permalink)
Member: 28095
Either flex cable or bottom connector!!!
Happened many times to me!
@gsmstyle
YOU ARE RIGHT
Old 04-29-2004, 18:28   #11 (permalink)
Member: 24929
Thanks Meter: 7
@gsmstyle
YOU ARE RIGHT
I think so, i fix many many 8910 with this problem, buy a good flexcable for €35 and your problem is fixed
Old 04-29-2004, 20:39   #12 (permalink)
Member: 39601
Thanks Meter: 13
@gsm_style....
If U read carefully , I told him to ( check the path ..All ) that includes the flexcable too. From the UEM to it again ( Headset detector pin to the socket and back ).
The man sayes that he changes the flexcable and he founds three brocken tracks !!! .
His question was , what makes the phone thinks that the headset is pluged.!!!
Have a nice time M8
Old 04-29-2004, 20:50   #13 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
I had a similar problem and i cleaned only the bottom connector with ultrasonic and it worked fine.
Old 04-29-2004, 20:55   #14 (permalink)
Member: 24929
Thanks Meter: 7
@gsm_style....
Have a nice time M8
Hi Metz
You're right, soory, no hard feelings M8
Old 09-14-2005, 08:34   #15 (permalink)
Member: 169368
Thanks Meter: 3
mr medz may be right, i changed my flex cable 2 times and still now use. I will try to trace lines to uem. I will post results. tnx!
3250 always on handsfree profile fonejack Nokia Hardware & Hardware Repair 1 02-26-2009 21:37
w810 always on headset profile sygnal Sony Ericsson Hardware Repair 3 12-19-2006 18:42
w810 always on headset profile sygnal Sony Ericsson Hardware Repair 2 12-19-2006 09:14
8910 always on "HEADSET MODE" help pls scotch7 Nokia Digital Core Technology 4 ( DCT-4 ) 4 11-03-2005 06:04
Page generated in 0.42518 seconds with 8 queries
