02-07-2004, 13:47 | #1 (permalink) |
Freak Poster Join Date: May 2000 Location: Slovakia
Member: 1341 Status: Offline Thanks Meter: 0 | 9210i CS - COBBA SERIAL FAULT I had one piece of 9210i with CS... NokiaTest checked phone and write Cobba serial FAULT. So I changed cobba..and result was the same... Then I try to flash by Griffin - nothing change... NokiaTool 1.8 can't change imei or calculate FAID.... After all this phone after insert battery without pressing key show CS on the front display...and big display inside boot normaly... Could be problem in MAD LINDA??? Can someone help me with this.... Thanx REpro [email protected] PS: on my board missing D354(32mb flash...)... is it correct??? |
02-10-2004, 19:27 | #5 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Cairo-Egypt & Shenzhen-China Age: 53
Member: 9963 Status: Offline Sonork: 100.65331 Thanks Meter: 216 | hi, try to desolder Cobba and read the 9210 cs fault if cobba serial this mean it is problem from MAD , if the error change to be cobba pararell this means the cobba is bad or not solderd good try to but a new one |
02-10-2004, 19:27 | #6 (permalink) |
Member: 1341 Status: Offline Thanks Meter: 0 | Cobba... Thanx for post... As I wrote I change COBBA with new one....but result was the same... Then I try to flash with GRIFFIN...same result... CONTACT SERVICE... and COBBA SERIAL FAULT MAybe something with PCB.... REpro |
04-22-2004, 23:50 | #9 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | good idea cairo_gsm... could we use it with all other nokia models? @repraky: cobba could be OK... but sometimes I have changed cobba 3 times for get a good cobba (there is a lot of defective units in market) b.r. |
Cobba serial or parallel | zaenalfaruqi05 | Nokia Hardware & Hardware Repair | 4 | 07-11-2005 14:48 |
COBBA serial ,,COBBA parallel | hanoon | Nokia Hardware & Hardware Repair | 2 | 02-03-2002 06:10 |
COBBA serial Faild | hanoon | Nokia Hardware & Hardware Repair | 4 | 01-28-2002 06:42 |
8890 cobba serial = *FAILED* | bluelights | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-20-2002 20:13 |
