07-17-2004, 20:24 | #2 (permalink) |
No Life Poster Join Date: May 2004 Location: Bandung-Flasher.com
Member: 65947 Status: Offline Thanks Meter: 135 | try mmc with other 9210 phone, if work ok you must check mmc connector. if still, reformat ur 9210 by pres ctrl+Shift after battery inserted. but you will lost ur data. BR |
07-28-2004, 17:19 | #3 (permalink) |
Junior Member Join Date: Jul 2003
Member: 35576 Status: Offline Thanks Meter: 0 | no need to format. first check the MMC is ok, then check the SIM reader cum MMC cover ( cover near Battery) of 9210I for a projection on the left side.this projection on the cover works as a switch connection on the board.u can see this near the screw come under sim slot.if this one is ok then go ahead with mmc connector and related repair.good luck |
08-13-2004, 08:06 | #5 (permalink) |
No Life Poster Join Date: Nov 2002 Location: cellworld Age: 47
Member: 17907 Status: Offline Thanks Meter: 42 | if not accepting only this mmc.may be your mmc corrupted. you can recover it. go to file manager then select menu button then go to memory card option. here only format memory card is enabled. format it. enjoy |
08-16-2004, 00:07 | #7 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
Second try to see [here] Max_B | |
Sl45 Mmc Not Detect | miecom | Siemens Hardware Repair Area | 0 | 02-04-2007 23:05 |
S65 not detecting RS-MMC card | Lupo | S-Gold Based Phones | 1 | 07-21-2006 12:56 |
¯`·.¸¸.-MMC not detected by PC-.¸¸.·´¯ | SALNAI | Hardware Repair by brands | 3 | 07-25-2005 12:16 |
MMC not detected in 9210 | TokeiLampin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 06-19-2005 20:39 |
Mmc not detected | coticj | x1x to x45/x50 | 8 | 06-26-2004 05:14 |
