05-10-2010, 10:13 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | About BB5 Contact Retailer Locked For All Provider & RPL WRITE Info About Contact Retailer In BB5 & SP Area Damaged & RPL Write Phone. Few Things You Have To See Before Repair. 1 Phone IMEI Is Damaged Or Not? F.E 123456789012345 2 Phone Sp Area Is Damaged Or Not? F.E Config key -FFFFFFFFFFFFFF & PROVIDER - unknown 3 Bb Self Test You Can Do With Service Option. Security Test Simlock Test 4 What Can We Do If IMEI Is Damaged? A.Simple And Easy Way To Repair Is If You Don't Have Backup. Calculate Bb5 Ask 2 Rpl And Write It. B.Free Way Is Downgrade Phone Then Check. If IMEI And Sp Area Still Damage Update Back And Use Ask 2 Rpl. 5 What If We Have Sp Area Damaged? (F.E Configkey –FFFFFFFFFFFFF & PROVIDER - unknown ) A. Simple And Easy Way Is If You Have Backup Of Pm 308(Eeprom In Hex 134) Restore It With Write Pm. Remove Phone Insert Battery And Plug Again And Test Phone. B. If You Don't Have Backup Just Use Bb5 Ask 2 Rpl To Repair It. 6 What If I Have Backup Rpl And Not Have Pm Backup? A. Backup Rpl Is For Certificate To Repair Or Restore. So In This You Can Restore IMEI Of Phone But You Can't Restore Sp Area.F.E Configkey –FFFFFFFFFFFFF & PROVIDER - unknown 7 What If I Have Backup Pm And Don't Have Rpl? A. You Can Restore Or Repair Sp Area But U Can't Restore Or Repair Phone IMEI (Certificate) With Only Pm You Need Rpl Backup Or CALCULATED RPL ONLY WAY. 8 Can I Restore Rpl With Usb Cable? A. No You Can't Write Rpl (Certificate) Via Usb Because Its Need Active Flash Mode. 9 What I Do After Rpl Write Still Contact Retailer? A.Most Phone Need To Rewrite Pm Field [1] And [309] For Writing This Fields Pm File You Have To Do SX4 With Supported Tools Then Do Fast Do Not Restart Or Off Phone Before Writing Pm File. B.Most Phone Can Repair With Downgrade And Write Rpl Then SX4 Write Pm To See If Same Then Update Back Then See If Solved Or Not. 10 How To Get This Pm Section? A.Read Any Working Phone Pm 1 To 512.Save To Pc.Open It To Notepad And Remove Field - [308] From It Save Again...Now U Can Us It. Note That If U Forget To Remove 308field From That Pm Before Writing U Get Damaged Sp Area Phone After Writing This Pm. B.You Can Also Use Only Pm Field - [1] And Field - [309] Also. 11 Can I Use Any Firmware Pm To Any Firmware? A. Some Phone Have Security Check For Rf Value.So Test If Not Work U Need Correct Version Pm. 12 What If Still Have Problem Contact Retailer? A.Do Self Test And Check St Security Test Is Failed Or Not?If Yes Then Read Post Again.If No Then Read B And C B.If Self Test Pass Then Do Factory Default And After That Do File System Format . C. As I Think Its Possible From Hardware Also So Check Hardware Section For More Help.. As I Think From My Side [Retu Ic] Responsible. 13 What If I Get Can't Decode At Rpl Write Or Corrupted? A.Best Way To Solve Contact Rpl Supplier.There Is No reason To Give Answer About This Problem Because JAF Team Not Making Any Rpl By Them Self.. 14 What Is SX4 ? A. SX4 Is Card By Nokia Work With Fps10 Fps8 To Calculate RPLS And Give Authorization Password To Phone. 15 Why We Need SX4? A. To Change/Rewrite In Pm(Eeprom) Sections Fields. . SX4 Calc Password For Phone. Because Nokia Have Protected Pm(Eeprom)Field [1] And [309] B If We Need To Rewrite This Filed We Need To Use SX4. 16 Why Some Phone Have Problem Rpl Write But Still Sp Area Damaged? A. Simple Your Can See Your Phone IMEI Is Restored Or Not. If It Was Damaged. Then Rewrite Rpl And Test Phone With Battery. If Its Not Damaged Then For Sending Sp Area We Need Local Mode Or Test Mode Because Phone Don't Accept Sp Area In Normal Mode. 17 What Is reason To Use Rpl? A. Many reason To Use Rpl I Write Here. [1]To Repair Config key = FFFFFFFFFFFFFFF [2]To Repair Provider = Any Digit Or Number Or Show Unknowed [3]To Repair Phone IMEI Damaged To 123456789012345. [4]To Repair Contact Retailer Come Because Field[1] And Field [309]Damage And Corrupted [5]To Repair Finished Counter Keypad Counter = 3/3 Fbus Counter = 10/10 18 How To Know That Rpl Come Is For Locked Phone Or Unlocked Phone? A. There Is 2 Way.. [1]Just Write Rpl And See Lock Area [2]Real One. Ask Any Nokia Access Owner To See Your Phone Warranty Before Process For Rpl. He Will Show This Type Of Info. Serial Number: 35938*************** <------Your Phone IMEI. Warranty: No <--------Your Phone Warranty . Warranty Class: Standard 15 (Shipment + 15 Months) <--------- Warranty Time Product Type: Rm-78 <--------- Phone Nmp Code For Firmware Handset: 6280 <--------- Phone Model Name. Product Code: 052***x <--------- Product Code For Sales At Which Country. Start Of Warranty: 27-03-2006 End Of Warranty: 27-06-2007 Ship-To Country: Ae-United Arab Emirates <------- Sales Country This Phone Belong To This Country. Ship-To Customer#: Factory Simlock: N <---------------- This Is Most Important For Us. Its Show Factory Lock Status N = Not Locked Y = Yes Locked use this link to get ur warrenty info. HERE 19 How To Bring Phone To Local Mode Or Test Mode At Fbus Cable?. A. You Need To Do Modification At Cable Bsi Wire To Bsi Pin And Also Have To Do Modification At Bsi Pin To Gnd Pin. Modification Need Resistor Value 7.5k to 10k [test which is working for ur phone]For Bsi Pin To Bsi Wire Come From Rj45 Cable.68k Value For Bsi Pin To Gnd Pin At Service Cable. Note: I added image file to show more clear info. Please see this image file to understand more.also some phone have different place bsi line you can see at battery or service cable before applying this. use only thanks |
05-10-2010, 10:17 | #2 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | 23 how to TEST BB5 FULLY IN SOFTWARE OR WRITE MODIFIED PM WITHOUT SX4 OR REPAIR VARIANT DATA DAMAGED PHONE OR DOWNGRADED so what to do to test bb5 fully ?? use fbus cable like jaf support 7 pin rj45 cable. and mt box support tx2 base rj48 pin cable. both tools have backup option. at jaf u can go to crt backup (for new phones like n95 8gb and others tick on include ape) & click at backup. its save plan format rpl. and read 301 to 310 pm field with read pm option. u can also read 1 and 309 in case you don't have modified pm you can use them next time. but be carful only section 1 and 309 need better to use my ready made modified pms. download from BB5 F.A.Q. link both updated. now we are ready to do erase and fully test bb5 in software. with jaf select "BB5Erase_UNI_rapido.bin" file as mcu if fail select as ppm with mt box select "BB5Erase_uni_rap.bin" file as mcu if fail select as ppm now click on flash. after flash finish. you see phone is fully dead. now select any firmware but please don't select too old or too new because we gonna need it in some case. now ur phone is on with imei damaged 1234567....and sp area should be FFFFFFFFF means corrupted. first step is restore ur 308 backup.in case if you are not able to restore you have to use same firmware version you have it before when you take backup. now wait 1minute after write.......... and replug cable to phone and check you get SP AREA repaired or not. if repair means backup accepted if still damage then you have to use same firmware version you have it before when you take backup. now phone is on contact retailers or imei damaged only but fully working I mean. at time you can write MODIFYED PM WITHOUT SX4.. because phone certificates is not in it so no need to do sx4 just select modified pm and write it. now we can restore RPL backup which we made before. now check phone info you get IMEI back or not phone should be on with contact retailer or fully working now… but if after restore backup in case your imei still damage or your phone show only nokia. rewrite “MADE BY ME DAMAGE SEC ZONE OF BB5 by chevli.rpl” idea by karwos. after this your phone imei is damaged and phone have contact retailer. now in this case you need calculated rpl it will fix imei area. replug cable and check both are IMEI and SIM LOCK repair or not? if repair means your ready to go for SX4........ if not means your flash ic or rap3g not accepting original data (CALCULATED RPL) even means any of it damaged need to do hardware work. sx4 is authorization as u know i write in my faq thread. with jaf tick on sx4 and press service. as soon as you get done......... WITHOUT REMOVING ANYTHING CABLE OR PHONE should be at same condition as it is. now tick on write pm. write modified pm which have 1 and 309 section in it. or we saved before 1 and 309 u can write them its same. now this is what we call software testing any bb5 full repair method. some extra tips. WHEN WE WRITE “DAMAGE SEC ZONE OF BB5 by chevli.rpl” we can write modified pm without SX4.as simple as we write normal pm. but after it YOU HAVE TO RESTORE BACKUP RPL NPC_DATA SO FIRST TAKE BACKUP BEFORE DOING IT. when we have damaged BB5 phone with downgrade show only nokia blinking or VARIANT DATA damaged. backup crt (imei or rpl any you like with any tool) first. we can write “DAMAGE SEC ZONE OF BB5 by chevli.rpl” to get local mode or test mode. now you can see you can do info and all that phone will work without any contact retailer or any problem. but phone will work with imei 123456789***XX which make it off in every 2 or 5min. now take backup of your phone sim lock area (308 I mean) now open your ORIGINAL RPL(which we backup first) in notepad. now you can see there all .. we need ALL NPC DATA to repair phone IMEI nothing else. so what we do is copy all NPC_DATA_1 2 3 4 EVERYTHING AND PASTE IN ONE FILE SAVE THAT ALL PASTED DATA FILE AS RPL. now restore that saved file and you see your phone have imei. in case of contact retailer you can do sx4 and write modified pm. in case of still nokia blink only way update it to new version. in case of “DAMAGE SEC ZONE OF BB5 by chevli.rpl” write show failed to connect need to update to newest version of nokia. in case of dead phone do erase method which mentioned on top. this will fix your VARIANT_DATA problem also.. to write "DAMAGE SEC ZONE OF BB5 by chevli.rpl" user must tick on PLAN RPL AT JAF CRT TOOL OPTION. |
05-10-2010, 10:24 | #4 (permalink) |
Member: 149032 Status: Offline Thanks Meter: 3,808 | 20 What Is Local Mode & Test Mode? How Many Modes In Bb5? What is Test mode, Local mode & TestPoint ? there is no perfect info about it. but i know something may help you. before Nokia like dct3 dct4 wd2 Tiku phones have only 3 mode normal mode local mode test mode but in bb5 there is 4 mode normal mode offline mode RF inactive local mode test mode normal mode is for phone be at normal condition like we use with battery and calling etc. local mode is for reading & writing phone pm area (eeprom),file system formatting etc. test mode is for doing file system removing like full factory defaults its also can do pm area rewriting and reading. RF inactive mode will be on phone same as normal mode but don't let RF = network part to work.means offline mode.without network. without local mode and test mode your not able to read info edit pm section like security code file system format factory defaults many things. this may be sort definition of modes. hope this help you. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
