Old 08-03-2004, 07:56   #1 (permalink)
Member: 2625
Thanks Meter: 2
Arrow About hagar chip.
Hi
How I will know when Hagar is broken.
What function is of hagar and how common is to need to change it?
Regards
Old 08-03-2004, 08:06   #2 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
I think Hagar is responsible for signal problems
Old 08-03-2004, 09:04   #3 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
@ Format1
Your Hagar can cause a signal fault or your handset to be dead as well
Regards D.
Old 08-03-2004, 09:18   #4 (permalink)
Member: 2625
Thanks Meter: 2
Hi
Thanks for replay`s.
How many times did you have need to change Hagar.As far I can read massages most problem with signal cause bad PA, bad Ant. Switch or Cobba.
How I can get suggestion when Hagar is broken.
Thanks
Old 08-03-2004, 09:38   #5 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Almost None.
Most faults where detected on PA and antenna switch
Old 08-03-2004, 09:48   #6 (permalink)
DMD
DMD's Avatar
Member: 12660
Thanks Meter: 7
I agree with leosedf
Hardly any sometimes have to reball/resolder them
Regards D.
Old 08-03-2004, 10:21   #7 (permalink)
Member: 2625
Thanks Meter: 2
Hi
Well I order 5 pices of Hagar.Because that I asked question.But never mind it wasn`t so expansive.Maby I will need it some day.
Tell me how about Cobba and Ccont.???
Thanks again friends for your`s time.
Regards
Old 08-03-2004, 17:37   #8 (permalink)
Member: 72579
When cobba faulty than you have similar situation like when is PA faulty.I usualy,when i get phone with faulty signal,like no network at all or have network for few sec.,first rehot PA and cobba.If still the same,change PA,and if stil the same replace cobba.I never reball it because cobba is so cheap
ccont faulty you can recognise when phone turn off by it self,when baterry empty quick(also PA faulty can empty batt for short time),when phone is dead...
Old 08-04-2004, 01:06   #9 (permalink)
Member: 72579
When you have no network at all than could be hagar,but cobba causes meny faulty of network also 32.768 KHZ REAL TIME CLOCK and Flash IC somethimes
Old 08-04-2004, 08:59   #10 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
And 26MHZ Crystal for Rx
Old 08-04-2004, 10:15   #11 (permalink)
Member: 2625
Thanks Meter: 2
Hi
Guys thanks for sharing all this to me very important informations.
Since phones have RX and TX what that exacly mean.?
How phone will act if RX is not ok and how when TX.
Is that mean if I`m able only to make call and not to recive that mean that TX is OK and RX is not OK.
Thanks
Old 08-04-2004, 10:49   #12 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Rx= Reception
Tx= Transmission
I think in case of one RX problem your signal goes up for a few seconds and then drops
Old 08-04-2004, 11:15   #13 (permalink)
Member: 2625
Thanks Meter: 2
Hi
OK.
Thanks and best regards
P.S. If somebody have more sugestions or comments please feel welcome to replay.
Old 08-04-2004, 19:33   #14 (permalink)
Member: 72579
Originally Posted by leosedf
Rx= Reception
Tx= Transmission
This is Tx problem,it causes faulty PA,Ant.Swich and cobba in most cases
Old 08-05-2004, 18:41   #15 (permalink)
Member: 25067
Thanks Meter: 76
in my opinion when your phone have tx faulty it mean you will get all network by manual network search and rx you did not find any net at all or you dont get full net service
About Spreadtrum CHIPS swensonb PadFinder box 6 05-02-2008 13:48
Need Explaination About BB5 Chips? parvezjk Nokia Base Band 5 ( BB-5 ) 1 07-29-2007 17:22
About Programming Chips ndagi Off Topic Zone 0 03-26-2006 16:09
Anybody knows something about Flash chip programmer LK48? Bobi Hardware Equipments for GSM 0 01-11-2005 13:44
Can Nokia power on without hagar chip ? Bemsas Nokia Hardware & Hardware Repair 4 08-01-2002 05:37
Page generated in 0.41298 seconds with 8 queries
