Old 02-02-2004, 08:48   #1 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
Make yourself BGA tin balls.
Hello all,
Try this and post result here.
1- Cut solder wire length 1 m.m. peaces [i use solder wire Alloy 63/37,dia. 0.4 m.m. flux-390, core 5B]
2- Put solder wire peaces are on a small glass wool [6" x 6" in a
matel tray] peaces aren't contact with each other.
3- **** hote air on it. set temperature that can melt solder wire.
not too much. [more temprature can melt your glass wool and it stick with ball. now your solder wire turn in to bga ball.
4- Now mess balls by bga pad, or your own way. what size of balls
you want.
[ you can change solder wire length as your requirment ]
sorry for my english
W.B.R.
Old 02-14-2004, 20:26   #2 (permalink)
veeresh's Avatar
Member: 26209
Thanks Meter: 2
its time consuming job. balls are readly avaliable
Old 02-15-2004, 00:12   #3 (permalink)
Porter's Avatar
Member: 19633
Thanks Meter: 13
nosens... If theare no bga balls - use melt paste and BGA matrix for create it direktly on bga chip. It`s more fust and easy.
Regards.
Old 02-15-2004, 11:07   #4 (permalink)
Member: 8704
Or anybody should have his own metod.
You can rehot bga then push down the chip(on board) with care,
get out the chip,if previously not seriously broken ball,you will have all balls on chip
clean the board around bga and then solder back bga
Old 02-15-2004, 14:11   #5 (permalink)
Member: 18057
Thanks Meter: 64
without ball possible to fit bga on ball, but needs some practice.......
b.r.
akki
Old 12-17-2012, 13:54   #6 (permalink)
Member: 1527391
Sonork: biplobaroj
BGA Solder ball making
Old 12-17-2012, 19:01   #7 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 305
dont waste time,buy several kind of staincils from the market and a P P D paste,a surgical blade .and make every ic small or big as you wish,
n95 bga solder balls size Toqeer1986 Nokia Base Band 5 ( BB-5 ) 1 03-11-2009 02:27
I need BGA IC ball making MACHINE DrMobile Hardware Repair Item Wanted 5 09-08-2005 21:18
BGA solder balls/BGA reballing kits Eisdieler Wanted Products 0 09-23-2003 09:26
b.g.a. tin ball purchase from u.k. baraka42 Main Sales Section 0 03-16-2003 12:35
How to make yourself grounded!! Abdul Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-23-2000 22:58
Page generated in 0.21967 seconds with 9 queries
