03-04-2005, 16:40 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Administrators where R u ??? I need Help !! |
03-04-2005, 18:25 | #2 (permalink) |
Freak Poster Join Date: Aug 2003
Member: 37787 Status: Offline Thanks Meter: 0 | if you replace the cobba you need to replace the hex codes. I'm not sure if your box does this but if the cobba has no hex codes it will not get any signal. If you do a manual search and the phone finds a network and you try select it and it says no access then it is normaly the pa. Dont just change parts if you are not sure you make the problem bigger then. |
03-04-2005, 18:38 | #3 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | Sir actually Iam not so much new, I know after replacing cobba we need to update sim locks and faid, but the problem is while manual searching it says no network found. dose not shows any network to select. If it would have shown any network to select I wodnt have given u trouble of asking this question, plz sir help me |
03-04-2005, 18:40 | #4 (permalink) |
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | and no body from the seniors in this feild of mobile repairing have assured me that they will definately repair this problem in my country. no one have know this problems solution |
03-04-2005, 23:53 | #5 (permalink) |
Member: 37787 Status: Offline Thanks Meter: 0 | what software do you use to do a faid update? You do know that if you change the haggar that you are suppose to tune the phone up again. I use to change them without doing it though. This is what i use to do when i had no tools When you first get the phone. test it. Do a manual search. How long does it take to come up and say no network? if it is fast the cobba should be working.. If it is a long time reflow the cobba or replace it. If it is fast then you can move on look for phisical dammage to components in the rf section. If you see nothing then take off the ant switch(diplexer) have a close look to see if it is cracked or if it has all the pads attached to the bottom of it, it is a common fault thet the pads underneath break off. if that looks ok then i would say replace the haggar. Hope this helps you. any more problems email me. |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
Dont know where to post this. need help with nokia 5200 | shivkk | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-16-2007 12:03 |
NEC : WHERE IS THE SOFT ???? NEED HELP FOR DB 2000 | chipi | Various | 0 | 09-08-2000 13:01 |
