01-06-2006, 18:07 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: mars under soft & hardware....
Member: 217604 Status: Offline Thanks Meter: 12 | ????????????? after changing flash loader! |
01-06-2006, 18:51 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 50
Member: 6358 Status: Offline Thanks Meter: 10 | It's perfectly normal to have corrupted imei after changing flash IC, simply because imei stored in flash has to be the same as the one stored in UEM. If you want to repair it without changing UEM, you'll need an RPL from the same imei stored in UEM. There is two options available: 1- Backup RPL before changing flash IC, then restore it. 2- Use ASK->RPL calculation, available by logs from Griffin server, for example. Best regards |
01-06-2006, 19:08 | #3 (permalink) |
Member: 217604 Status: Offline Thanks Meter: 12 | FONTELENSE, i use ufsx series.how do i back up rpls on phones which cant power on?these phones are always unknown flash problems when you try to flash even if you reball the chip.how do i backup this? thanks in advance |
01-06-2006, 23:43 | #5 (permalink) | |
Freak Poster Join Date: Jun 2000
Member: 1641 Status: Offline Thanks Meter: 54 | Quote:
unknown flash , the mean flash was dead. how to make backup????????? | |
01-07-2006, 10:35 | #6 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | If the phone is dead you cannot backup rpl so the solution is rpl calculation or put another UEM that is empty (after you changed flash IC if is faulty) and program it with any rpl . |
01-07-2006, 17:16 | #7 (permalink) |
Member: 217604 Status: Offline Thanks Meter: 12 | i always change two things as i told you.flash loader and uem in order to get a good working phone but i want any way whereby if am to change flashloader,uem doesnt corupt.any way?if its only uem,it doesnt need flash loader changing.but when flash loader,it needs uem too.ooh plz help me coz some new model phones,i dont have uems for them and i want to repair them.i cant let go. thanks too all members. gsm wizard. |
k800 after change flash ic how to flash ...? | jimmyyew1981 | DreamBox | 7 | 03-16-2009 18:19 |
V300 after change flash chip | diablos | Motorola Hardware Repair | 0 | 12-02-2005 13:04 |
c62 after change flash | BATTAL | NON Siemens Brand (ODM Phones) | 7 | 02-02-2005 14:21 |
3310 after change Flash Ic | Zabra | Nokia Hardware & Hardware Repair | 11 | 08-05-2004 11:46 |
