Old 08-07-2005, 14:22   #1 (permalink)
Member: 139043
Thanks Meter: 27
After using flux to reheat pcb, must i clean the pcb??i cannot flash phone after that
everytime when i reheat the pcb with flux and then i tried to flash the phone it doesnt flash any more.
before i apply flux to the phone i can flash the phone twice or more but after flux i could not flash the phone anymore. it happen to all my phones that has flux on it.
the question is should i clean the board with a spirit after i flux the phone?
Old 08-07-2005, 17:56   #2 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 11
maybe your flux is not original... used original or some duplicate but good flux. try to use like this flux type:rma-223, lot no:365-02-1(u.s.a. made).
Old 08-11-2005, 17:12   #3 (permalink)
Member: 139043
Thanks Meter: 27
i have just check my flux and it is exactly the one u mention. by using original flux i do not need to clean the board isit?
Old 08-11-2005, 17:31   #4 (permalink)
AndreS's Avatar
Member: 36951
Sonork: 100.63212
Thanks Meter: 6,247
to conect the rphone to the computer, you need to clean the area of conection.
not necesarily the entire PCB
Old 08-11-2005, 17:36   #5 (permalink)
Member: 139043
Thanks Meter: 27
i have done that and it still doesnt flash at all it always comes out error. i did not use very hot air to **** the pcb i use around 270 deg.
Old 08-11-2005, 19:01   #6 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
Hi,
The first u need check ur phone by power supply (for A).
Clean PCB and cable.
Flash again.
B.R
Vinh Hai
Old 08-11-2005, 22:12   #7 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
If you use paste flux, always clean board, many paste flux are corosive, better use liquid one
Old 08-12-2005, 05:33   #8 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
Why rehot PCB? nextime, just rehot a fixing IC or component (choiced component) with some of good flux and do not rehot all of PCB.
About can't flash after rehot with some flux, thats happen if you rehot all of PCB (full rehot), there is isolated pin connector flash port with some flux, clean it with 96% of alcohol with cotton bud.
sorry for my bad english
Old 08-12-2005, 07:55   #9 (permalink)
Member: 137686
Thanks Meter: 3
try to rehot u'r ic flash. and then try to flash u'r phone again. may be u'r ic flash damaged.
gudluck
Old 08-13-2005, 14:17   #10 (permalink)
Member: 139043
Thanks Meter: 27
thanks for the advise i have clean the board and i can flash it again thanks a lot guys
K750 R1CA021 cannot complete phone after downgrade to R1BC002. mentari SonyEricsson (USB-Smart) 15 08-09-2006 15:32
Can We Use Tornado Or Jaf Box To Unlock And Flash Phone After Active Com 1????? cobra02a NSPRO 3 01-08-2006 23:50
What do you use to clean the pcb with when there is flux?? smartfone Nokia Hardware & Hardware Repair 5 06-24-2005 14:31
motorola p2k cannot conect phone after install driver.help! crossings Motorola P2k 1 03-16-2004 05:20
pemaster and roemmi cannot flash anymore after 80K writting crossings Motorola Old Legacy (EMMI) 1 02-02-2004 16:47
Page generated in 0.19547 seconds with 9 queries
