07-01-2003, 17:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: home
Member: 15506 Status: Offline Thanks Meter: 3 | again charging...3210.... I change IC of charging, varistor , check contact on batery nothing help? Any idea? Thanx! |
07-03-2003, 09:08 | #5 (permalink) |
Member: 15506 Status: Offline Thanks Meter: 3 | no is not ccont, I try all, nothing help....! I manual recharge batery and when I connect charget, when is mob turned on on display show Not charging...... But when is mob shot down, then is same problem....(blinking pic of batery on display).... |
07-03-2003, 10:12 | #6 (permalink) | |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | Quote:
Check battery connector. and also cap. res. near battery connector.. and some time BROKEN PRINT from BATTERY CONNECTOR TO CCOUNT. Best Regards, Wahab | |
07-03-2003, 10:28 | #7 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | Enable netmonitor go to test 20, then see message shown on the top right corner. Also see what's the temperature measured by the phone, if it's with "-" in front. Also check battery connector. Press it and look if it's raising from the board. In this case temperature sensor is out from circuit, and phone measures wrong temp (-17 C), and will prevent charging. Anyway look for error on test 20 in netmon ! |
02-21-2005, 17:06 | #8 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Lithuania Age: 40
Member: 93240 Status: Offline Thanks Meter: 8 | Quote:
samsung e330 problem charge? | cerimobil | Samsung Hardware Repair | 1 | 08-01-2012 10:40 |
3210 charging problem again | garcea10ro | Nokia Hardware & Hardware Repair | 5 | 05-16-2003 03:20 |
3210 Display charging, but not charging | DrMobile | Nokia Hardware & Hardware Repair | 2 | 09-17-2002 20:46 |
3210 shows charging, but not charge actually. | sat | Nokia Hardware & Hardware Repair | 6 | 11-02-2001 01:28 |
3210 charging restarts endless and no charging | iHi | Nokia Hardware & Hardware Repair | 3 | 10-17-2001 20:10 |
