03-31-2008, 05:08 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: jamnagar
Member: 321534 Status: Offline Thanks Meter: 18 | 6600 phone start up failed contect the retailer i face the problem in 6600 phone start up failed. ... i try to manual format whith *-call button-3 and power on but format proccess not complite, i also try to manual erasing process whith jaf and ufs both but last area can not erase and error comming. i strickly resold cpu and s-ram also but not success still phone has same condition. please if any body has perfect solution share whith me. i confused thanks in advance... |
03-31-2008, 07:20 | #10 (permalink) |
Freak Poster Join Date: Mar 2006 Location: rajkot (india)
Member: 244357 Status: Offline Thanks Meter: 70 | are you crazy ? this is a normal software problem. is solved by ufs , just make full factory then press normal mode, after normal mode is activated (sometime it is may be failed , no wooried), then press test mode, then press formate user area, and last make normal mode again. probem will be solved easily. post the result . DON'T TOUCH THE UEM. |
03-31-2008, 16:53 | #15 (permalink) | ||
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | re: Quote:
N95 8gb phone atart up failed contect the retailer | sajidashraf | Universalbox | 23 | 02-10-2010 13:21 |
N96 Phone Start-up failed Contact the retailer (security Test failed in reading) | dmaetrey | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-08-2010 13:46 |
pls help me..!!6630 after flash phone start-up failer.contect the retailer | ahsam | Nokia Hardware & Hardware Repair | 12 | 05-26-2007 11:14 |
