Old 12-14-2008, 17:28   #1 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
Arrow All Nokia Mobiles Converting Guide Solution Ways
3100b Rh50 To 3100 Rh19
Flash It With Rh19
Write 3100 Special Pm File For Speaker
Ui Settings.
The Following 10 Users Say Thank You to khisrow For This Useful Post:
Old 12-14-2008, 17:33   #2 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
3200b To 3200
Only Change Filters And Write Good Pm File.
The Following 3 Users Say Thank You to khisrow For This Useful Post:
Old 12-14-2008, 17:39   #3 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
3600 To 3650
Change Filters
Flash The Phone With 3650 Flash Files V3.16 ,Write Good Pm And UI Settings.
The Following 4 Users Say Thank You to khisrow For This Useful Post:
Old 12-14-2008, 17:43   #4 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
6800a To 6800
Do As In Picture.
Old 12-14-2008, 17:50   #5 (permalink)
soy
soy's Avatar
Member: 220932
Sonork: 100.1592154
Thanks Meter: 110
thanks bro nice job plz add 5190 and 6300b
Old 12-14-2008, 17:53   #6 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
8390 To 8310
1. Jumper Resistor Is A Resistor (Not Actually A Resistor) With 0 Ohm Value, Usually Colored Green With 0 Markings.
Wire Can Also Be Use Instead, But Must Not Be Very Thin And Should Be As Short As Possible. Thin And Long Wire Will Introduce High Inductive Reactance And Will Result To Weak Received Signal.
2. T500 Can Be Taken From 3310 Unit. It Is Located Ust Above HAGAR, Refer To Your Service Manual To Easily Locate It. Also Take Note To Its Pin Orientation During Installation.
Bypassing Z551 With Wires Is Not Recommended,This Will Weaken The Receiver Sensitivity Due To Incorrect Signal Phase Relationship.
3. Give Special Attention When Installing VCO, Improper Positioning Will Result To No Network Activity
The Following User Says Thank You to khisrow For This Useful Post:
Old 12-14-2008, 18:01   #7 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
ngage qd rh47 to ngage qd rh29
DO HARDWARE AS SHOWN IN PICTURE.
1- Erase
2- Flash MCU and PPM (Ngage Qd Rh-29)
3- Write pm
4- Init lock
Old 12-14-2008, 18:04   #8 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
6102 TO 6101
FOLLOW THE PICTURE.
The Following 2 Users Say Thank You to khisrow For This Useful Post:
Old 12-14-2008, 18:06   #9 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
3390b to 3310
Full Flash With 3310 Firmware And Do Hardware Like In Picture.
Old 12-14-2008, 18:09   #10 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
1100b to 1100
1. Erase Flash
2. Flash With 1100(Rh-18)
3. Change Filters
4. Write Pm
5. Unlock
Old 12-14-2008, 18:12   #11 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
1600b To 1600
1. Change 2 Filters ( From 1600 )
2. Flash It To 1600 Rh-64 Firmware
3. Load 1600 Pm Files
4. Unlock
Old 12-14-2008, 18:15   #12 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
2600b to 2600
1. Flash It To 2600
2. Change Filters
3. Write Pm
4. Unlock
Old 12-14-2008, 18:23   #13 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
6010 to 3510i
1. Back Up RPL
2. Change Flash I.c, 3510i or 3530 Flash i.c,Then
3. Add a Ram To It
4. Flash It To 3510i,,Use Rh-9 V5.35 Flash File
5. Change The 3 Filters The 850/1900 mhz rx And 1900 mhz tx Filter,
6. Put A Jumper From Uem To Pa
7. Write Pm
8. Unlock
Old 12-14-2008, 18:27   #14 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
6030b To 6030
1. Like RM-225 (6030b) Convertion Jumper Or Change Two Filters
2. Write Good Pm 6030.Pm
3. Full UI Settings And Unlock
Old 12-14-2008, 18:31   #15 (permalink)
khisrow's Avatar
Member: 811386
Sonork: Gsm Afghan
Thanks Meter: 1,333
6061 To 6060
1. Erase Whole Flash As 6060.
2. Flash Your 6061 With 6060 Flash Pack "RH-73_dp_46_00_ams_sw_4_10".
3. Replace 2 Filters
4. Write Pm
5. Unlock
All Nokia Mobile Phones Convert Best Solution in one EXE sharee0007 Nokia Hardware & Hardware Repair 0 09-29-2009 19:42
All China mobiles hardware guide majidaziz Chinese Models & Cloned Phones 0 03-11-2009 18:41
some nokia moel convert guide....... digitized Nokia Hardware & Hardware Repair 0 10-22-2007 13:43
Page generated in 0.27223 seconds with 9 queries
