12-14-2008, 18:35 | #16 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Afghanistan
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 6101b To 6101 No Software Modification Is Required Coz 6101b Is Already A GSM Tri-Band (850_900/1800/1900) But You Can Also Flash It With RM-76 Data Package. Since Phone Is Tuned To 850 MHz Otherwise No Network Or Weak Network.. Write Pm (6101) |
The Following 3 Users Say Thank You to khisrow For This Useful Post: |
12-14-2008, 18:36 | #17 (permalink) |
No Life Poster Join Date: Apr 2006 Location: ***'S OWN COUNTRY;NIGERIA
Member: 268772 Status: Offline Thanks Meter: 102 | Useful post but it was old solution;the Phones are not really common again |
The Following User Says Thank You to pastorsam For This Useful Post: |
12-14-2008, 18:39 | #19 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 6103b To 6103 No Software Modification Is Required (6103b Supports 900mhz) Change 2 Filters Then Write 6103 PM Unlock |
12-14-2008, 18:43 | #20 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 8801 To 8800 1. Change Rx And TX Filters 2. Write With File 8800_Rm13_Short.Pm |
The Following 2 Users Say Thank You to khisrow For This Useful Post: |
12-14-2008, 18:47 | #21 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 15. 3650 to 3660 1. Back Up RPL 2. Change UPP V2.4 To UPP V3.2 3. Flash To 3660 V5.08 4. Change Uem 5. Write Special RPL File For 3660 6. Write Pm 7. Unlock 8. Replace 3650 Keypad To 3660 |
The Following 4 Users Say Thank You to khisrow For This Useful Post: |
12-14-2008, 18:52 | #22 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 3595 to 3530 1:Flash It To 3530 2:Change 2 Filters 3:Write A Good Pm 4:Unlock it. |
12-14-2008, 18:55 | #23 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 3220b to 3220 1:Change The filters 2:Upload Good Pm File 3:Unlock It. |
12-14-2008, 18:58 | #24 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 2651 To 2650 1. Change Filters Shown In The Picture You Can Use Filters From Nokia 3100 2. Full Flash With 2650 Files(MCU,PPM,CNT) 3. Write A Good Pm 4. Unlock It. |
12-14-2008, 19:08 | #25 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | All Nokia Mobiles Converting Guide Solution Ways All Nokia Mobiles Converting Guide Solution Ways 8390 To 8310 Jumper Resistor Is A Resistor (Not Actually A Resistor) With 0 Ohm Value, Usually Colored Green With 0 Markings. Wire Can Also Be Use Instead, But Must Not Be Very Thin And Should Be As Short As Possible. Thin And Long Wire Will Introduce High Inductive Reactance And Will Result To Weak Received Signal. 2. T500 Can Be Taken From 3310 Unit. It Is Located Just Above (HAGAR), Refer To Your Service Manual To Easily Locate It. Also Take Note To Its Pin Orientation During Installation. Bypassing Z551 With Wires Is Not Recommended, this Will Weaken The Receiver Sensitivity Due To Incorrect Signal Phase Relationship. 3. Give Special Attention When Installing VCO, Improper Positioning Will Result To No Network Activity |
12-15-2008, 17:11 | #26 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | Converting N95 RM-245 to N95 RM-159 Procedures Using J.A.F. N95 RM-245 = For China Provider Release (No internet Phone) File version released : RM-245_CHINA_11.1.010_v2.0(12.0.0.49974) Convert Phone Model To N95 RM-159 = With Internet Phone (And Regular Features) When Flashing In Ordinary Way, Phone Will Be In Nokia Logo And Fades. Procedures : Backup All Necessary Files Of Phone. Run J.A.F Software And Select BB5 Tab Click Inf To See Your Phone Model and Firmware Tick Manual And Downgrade Box, Select RM-159 (Flash Firmware RM-159_APAC_12.0.013_v3.3.0 Must Be Installed) And Click Flash (Note : Be Sure You Are Aware Of The Warning Messaging Of J.A.F. Warning Pop-Up Message) LOGS : JAF Version 1.98.34 Detected PKEY: 9000JAKE Card life counter: 95.02% P-key nokia module version 01.00 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v23.7 18-06-07 RM-245 (c) Nokia HW version: 5650 PCI version: RFIC version: 17141714 DSP version: dsprap_pb06w41v24 Retu version: 15 Tahvo version: 21 Production serial number: SGH965261 LOCK STATUS: CONFIG KEY: 0000000000000000 Provider: Unknown provider Key Code count: 0, FBUS Code count: 0 |
12-15-2008, 17:13 | #27 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-245.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0548021 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-245\RM-245_11.1.010_PR.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-245\V1RM-245_11.1.010_PR.vB5 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-245\RM245_11.1.010_003_UB5_uda.fpsx APE Variant file: NONE Done! Powering the phone... Reading Full PM... Reading Field 1 ... Reading Field 2 ... Reading Field 4 ... Reading Field 8 ... Reading Field 11 ... Reading Field 12 ... Reading Field 31 ... Reading Field 44 ... Reading Field 50 ... Reading Field 54 ... Reading Field 88 ... Reading Field 96 ... Reading Field 107 ... Reading Field 122 ... Reading Field 193 ... Reading Field 208 ... Reading Field 217 ... Reading Field 239 ... Reading Field 308 ... Reading Field 309 ... Reading Field 313 ... Reading Field 322 ... Reading Field 329 ... Reading Field 341 ... Reading Field 354 ... Reading Field 356 ... Done! Setting FLASH MODE Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready Loader version: 01.15.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready Reading CMT NPC certificate... Reading CMT VARIANT certificate... VARIANT CRT empty, skip save... Reading CMT CCC certificate... Reading CMT HWC certificate... Saved to C:\Program Files\ODEON\JAF\ProgData\35225501431778_CRT_backup _547310.rpl Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v23.7 18-06-07 RM-245 (c) Nokia HW version: 5650 PCI version: RFIC version: 17141714 DSP version: dsprap_pb06w41v24 Retu version: 15 Tahvo version: 21 Production serial number: SGH965261 Product code: 0548021 Module code: Basic production code: 0530865 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 352255014317782 IMEI spare to net: 3A 25 52 05 41 13 77 08 IMEI SV to net: 33 25 52 05 41 13 77 08 F4 LOCK STATUS: CONFIG KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 |
12-15-2008, 17:19 | #28 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-245.ini Saved INI not found, loading INI list... Setting local mode... Failed! Aborting! Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 06wk41v23.7 18-06-07 RM-245 (c) Nokia HW version: 5650 PCI version: RFIC version: 17141714 DSP version: dsprap_pb06w41v24 APE SW Core version: 11.1.010 APE Variant version: 11.1.010B5.01 APE Test version: rm159_ENO_x_2007wk02v0.070 Retu version: 15 Tahvo version: 21 APE HW version: 1 APE ADSP SW version: 256 APE BT version: HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10. Production serial number: SGH965261 Product code: 0548021 Module code: Basic production code: 0530865 Flash code: Order number: Product specific data: Long production SN: 0 ATO: Default SN type: IMEI plain: 352255014317782 IMEI spare to net: 3A 25 52 05 41 13 77 08 IMEI SV to net: 33 25 52 05 41 13 77 08 F4 LOCK STATUS: CONFIG KEY: 2440700000000000 Provider: AT&T;U.S.A. (3650) Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-245.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0548021 FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-245\RM-245_11.1.010_PR.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-245\V1RM-245_11.1.010_PR.vB5 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-245\RM245_11.1.010_003_UB5_uda.fpsx APE Variant file: NONE Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE FILES SET FOR FLASHING: (starting to downgrade part) MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-159\RM-159_12.0.013_PR.C0R PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-159\RM-159_12.0.013_PR.v11 CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-159\RM159_12.0.013_025_U05_uda.fpsx APE Variant file: NONE Languages in ppm: English,Simpl Chinese Backing up SIMLOCK data... Setting local mode... Reading IMEI... C:\Program Files\ODEON\JAF\ProgData\352255014317782_CRT_backu p_548310.pm Done! Backup LCK OK! Preparing for downgrade... Phone ready for downgrade! Manual mode selected, version can't be checked! Booting phone... APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 77BE3FE0E796E81EC281027A965DFCB221361514 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101011103 Asic Mode ID: 00 Asic EM ID: 00000B21 Asic Public ID: 1D900103CA4800584DC92F832A0A96EA639B831E HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: F2C6EBADC86E6189 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv102_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.22.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004800EC APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.2D.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... Getting APE Public Keys... APE Loader Ready... Operation took 0 minutes 10 seconds... Sending CNF Data... Sending CRT data... Erasing... Operation took 0 minutes 43 seconds... Writing... Stage 1 Sending APE HASH for X-LOADER Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending APE HASH for KEYS Sending CMT HASH for PRIMAPP Sending APE HASH for PRIMAPP Sending CMT HASH for PASUBTOC Sending CMT PUB KEYS... Sending APE HASH for X-LOADER Sending CMT HASH for UPDAPP Sending APE HASH for KEYS Sending APE HASH for PRIMAPP Sending APE HASH for SOS+XZIP Sending APE HASH for PASUBTOC Sending APE PUB KEYS... Sending APE HASH for SOS+UPDAPP Sending CMT HASH for DSP0 Sending APE HASH for SOS*CORE Sending CMT HASH for MCUSW Stage 2 Sending APE HASH for SOS+ROFS Operation took 7 minutes 17 seconds... Reseting phone... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-159\RM-159_12.0.013_PR.v11 |
12-15-2008, 17:22 | #29 (permalink) |
Member: 811386 Status: Offline Sonork: Gsm Afghan Thanks Meter: 1,333 | Booting phone... APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 77BE3FE0E796E81EC281027A965DFCB221361514 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101011103 Asic Mode ID: 00 Asic EM ID: 00000B21 Asic Public ID: 1D900103CA4800584DC92F832A0A96EA639B831E HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: F2C6EBADC86E6189 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv102_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.22.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004800EC APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.2D.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... Getting APE Public Keys... APE Loader Ready... Operation took 0 minutes 10 seconds... Sending CNF Data... Erasing... Operation took 0 minutes 0 seconds... Writing... Sending APE HASH for SOS+ROFX Operation took 1 minutes 48 seconds... Reseting phone... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-159\RM159_12.0.013_025_U05_uda.fpsx Booting phone... APE Boot Data: Asic ID: 24200705 Asic Mode ID: 00 Asic Public ID: 77BE3FE0E796E81EC281027A965DFCB221361514 HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 ROM ID: 0000000000000000 CMT Boot Data: Asic ID: 000000010000022600010006400C192101011103 Asic Mode ID: 00 Asic EM ID: 00000B21 Asic Public ID: 1D900103CA4800584DC92F832A0A96EA639B831E HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000 ROM ID: F2C6EBADC86E6189 CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv102_2nd.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 00350001 CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg Loader version: 01.15.00 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... Getting CMT Public Keys... CMT Loader Ready APE Boot: C:\Program Files\ODEON\JAF\Flash\omap2420_m1_2nd.fg Loader version: 01.22.00 -> Revision: 0000 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... APE Boot Ready APE Flash ID: 004800EC APE Flash Data: Not Available APE Loader: C:\Program Files\ODEON\JAF\Flash\teflon_sam_nand_xsr151_m1.fg Loader version: 01.2D.00 -> Revision: 0000 Patching APE loader step1... Patching APE loader step2... Patching APE loader step3... Getting APE Public Keys... APE Loader Ready... Operation took 0 minutes 10 seconds... Erasing... Operation took 0 minutes 3 seconds... Writing... Operation took 4 minutes 8 seconds... Reseting phone... Done! Total time: 14 Minutes, 33 Seconds DCT4/BB5 counter: 98 After flash processing... Waiting for phone to boot... Reading... Phone type: RM-159, Software version: 06wk41v31 IMEI: 352255014317782 APE Ver: (null) Variant Ver: (null) Product Code: 0548021 Done |
All Nokia Mobile Phones Convert Best Solution in one EXE | sharee0007 | Nokia Hardware & Hardware Repair | 0 | 09-29-2009 19:42 |
All China mobiles hardware guide | majidaziz | Chinese Models & Cloned Phones | 0 | 03-11-2009 18:41 |
some nokia moel convert guide....... | digitized | Nokia Hardware & Hardware Repair | 0 | 10-22-2007 13:43 |
