10-20-2007, 19:56 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | any way to check "display ic" working or not in 6600 using multimeter? i have not experience in hardware servicing.mainly doing software problems. in software service no headaches-but in hardware without experience lead to headache-i mean can not return to customer in the condition before buy to repair.so i did not do hardware. any hardware experts help me to avoid trial and error method.(because i think trial and error method in hardware service lead to complicate problems) i have a 6600 display problem(incoming/outgoing ok).check with another display-still no scope-solder display contacts in motherboard-checked display voltages VIO=1.8V,VFLASH1=2.8V to display connector-its ok-still no display. now the remaining components to check is display ic z140,v140 and upp. my doubt is any way to check DISPLAY IC working or not using multimeter? thank u |
10-21-2007, 14:59 | #4 (permalink) |
Freak Poster Join Date: Apr 2005 Location: INDIA Age: 43
Member: 138224 Status: Offline Thanks Meter: 56 | Yes 100percent posible u dont have good hardware exp. Get ok board n check it restance n compare to faulti mobile. U can check those resistance in display conector. Goodluck |
10-21-2007, 14:59 | #5 (permalink) |
Member: 138224 Status: Offline Thanks Meter: 56 | Yes 100percent posible. u dont have good hardware exp. Get ok board n check it restance n compare to faulti mobile. U can check those resistance in display conector. Goodluck |
10-22-2007, 12:01 | #6 (permalink) | |
Junior Member Join Date: May 2006 Location: india
Member: 274238 Status: Offline Thanks Meter: 2 | Quote:
1OO% POSSIABLE TAKE THE MULTIMETER IN OHMS RANGE AND CHEAK THE LCD CONNECTOR, THEN TALLY WITH A OK SET.............GOOD LUCK | |
The Following User Says Thank You to rohit jaiswal For This Useful Post: |
11-02-2007, 15:18 | #8 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 465901 Status: Offline Thanks Meter: 45 | put new lcd ic on double tape and check as said in display above with multimeter resistance must be about 200 ohms, because i always check old ic to check is it ok or not. put your multimeter in buzzer probe. |
The Following User Says Thank You to ZENITHMOBILE For This Useful Post: |
..:: Easy way to check Any point, Is it connected or No (Saif-Tc) ::.. | saiftc2 | Nokia Hardware & Hardware Repair | 33 | 09-23-2011 00:46 |
Easy way to check Iphone its 3G or 3GS !! | kmaxmax | iPhone 2 / iPhone 3G / iPhone 3GS | 15 | 02-24-2011 21:12 |
how to check my box activated or not | tarun batla | MT-BOX | 2 | 02-16-2010 07:47 |
Is there any way to check Factory Unlocked iPhone without upgrade??? | nasirahmed | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 06-25-2009 18:32 |
any way to check the uem is good?? | maxking | Nokia Hardware & Hardware Repair | 3 | 12-27-2003 15:16 |
